Twin Turbo Stock LS1 Engine Failure: Going out with a bang!
#63
For the original TTiX Turbonetics turbos,
Compressor housing is a T04B-H. Compressor wheel is a T04B Super H. Compressor wheel major diameter is 76.2mm and the minor diameter is 57.7mm.
Turbine side is a Turbonetics T3 5-bolt housing. You could get them in a 0.63 or 0.82 A/R. Turbine wheel is an F1-62. Turbine wheel major diameter is 71mm and the minor diameter is 61.8.
#66
Devin, thanks for clearing that up. I've always heard that the APS flange was different. Now it makes sense as to why the DKT housing is capable of increased power.
Do you have any comments on the airflow limit of the 6265s on a TTiX kit?
#67
I don't see the actual hole in the flange being the actual restriction in any of these t3 type housings. The hole on all of the housings (t3 v-band, t3 , APS, etc) have way more area than the actual volute where the turbine resides. You can't compare t4 a/r to t3 either. The best thing about the APS/DKT housing is that it is a 1.06 a/r so the biggest of the bunch.
About the best thing you will get away with on your 5 bolt housings with be running the .82 a/r(which you had) and upping the turbine to a f1-65. I see Champion did a Comp turbo with a 66mm wheel, but the material on the housing looks so damn thin at that point.
#68
It sounds like thats what happened to me .. it pretty much looks like the piston bottomed out .. i drove through water once and the car died , pushed it out . when i went to start it the motor would not turn .. after i taped the key about 10 times i finally got the water out and it started lol
#70
Once again, an interesting article not much discussed here in this forum:
http://www.hotrod.com/techarticles/h...g_bang_theory/
Ain't it nice?
Ain't it nice?
Because of other items discussed in this thread, I'm going to post this link to one option for Turbonetics 62-1 wheels in a B cover. I'm not sure if they are still available, but this is probably the cheapest way to get 6265s. I'm not sure of all the specs on them.
http://forums.corvetteforum.com/c6-f...post1583073636
#71
#76
This thread was mainly about the ending, here is a link to the new beginning: http://forums.corvetteforum.com/c5-f...eat-white.html
#78
I figured I would finish this one off with some pics of the main bearings. I never did post up any pictures. There is some wear both nothing out of the ordinary for an 86k engine that saw 7000 rpm repeatedly and over 800 rwhp.
All
#2 Main bottom bearing
#2 Main top bearing
#3 Main bottom thrust bearing
All
#2 Main top bearing
