Anyone rebuilt a vortech head unit before?
My impeller seal was leaking so I decided to do a rebuild and found the part numbers online for the bearings only to find that the impeller shaft bearings I got are too small. Are there different bearing sizes used in the same vortech units?
The old bearings are already gone. But from what I remember there were no writings on them which is why they just got tossed
Obviously any bearings used will depend on what blower it actually is.
Vortech's bearings will have Vortech's own numbers on them, so are of little use anyway.
But bearings are all based on size. ID, OD and width. So in that respect easy to find.
Now finding bearings with suitable speed ratings can be a harder task, especially the high speed side. The low speed are easy as they generally spin fairly slowly ( ie sub 20k ) and most of that size will be rated around that anyway
They seem to have a variable reputation.
And any bearings they sell, they grind the part numbers off them. So you have no way of knowing if they are actually suitable.
As long as the impeller isnt damaged and no other major damage. ie it's just a bearing and seal change, the actual work is pretty easy. But you will need a hydraulic press.
They won't confirm what bearing they sell either so you don't know what their speed ratings are. The work is def easy. I just can't find the part number that's correct to my case. It's a 17x40x10 15 degree angular contact set that I need rated for Abec 7. I'll just have to get on the phone with skf here on Monday.
I know I'm not the only one here that rebuilds this stuff themselves. Maybe I just have trust issues. That and I'm impatient.
Try searching yourself for high speed bearings that are rated to 65-70k.
They pretty much do not exist.
SKF and one or two others do list some in catalogues. But when I enquired none had actually ever been made and there were no plans to make them. That was anywhere in the world according to SKF Europe.
So I can only presume that the bearings both Vortech and others might sell are not rated for the speeds involved, but they just overspin them.
I have been given part numbers from others who have rebuilt using ceramic bearings. No idea where these were sourced from, as when I contacted the European suppliers with those numbers they simply didnt exist. Places I emailed in the US never even replied.
One Australian company actually uses the same size ceramic bearings in their turbochargers and said they would sell me a pair, until I tried to pay them. Then they seemed to stop all contact...weird people.
They may be trying to protect their investment....or they may be trying to deceive.. Without real information I will opt for the latter.
Most of ID's thing is sales pitch. That's why there are other sellers selling the exact same Bosch injectors at much lower cost. There is nothing special about their injectors, they were just great at marketing them.
Weird if those are original Vortech and never been rebuilt.
I bought a pair of those ( 7203CDYU ) precision bearings for mine, but never used them. The low speeds were a pair, 7205CDYU.
These are sold packaged as matched pairs, not single bearings.
But even those 7203C precision bearings are only rated to 31,000rpm as a pair, or 39,000 singly.
Which again backs my thinking up that they just use fairly normal bearings and just overspin them
Both original sets of bearings in my YSi were Vortech branded and Vortech part numbers
Maybe they've just stopped doing that and do fit normal makes of bearing
But then...the Vortech bearings arent rated for that either as they state 65k max for their blowers. I'd say Ive used 75k max on occasion
Their high speed bearings dont look like anything special, and mine were just normal metal bearings. Others with newer units have said theirs were ceramic bearings.
1 Post
The Nachi bearings (like one in pictures) are hybrid ABEC 7 (metal race w/ceramic *****). Can’t remember exact speed rating but in 40K+ RPM region. Last time I purchased a pair, think it was around $120 (USD).
As for supercharger rebuild, the reason for grinding off numbers is you are likely getting ABEC 5 bearings at ABEC 7 prices. Then he also doesn’t buy “known” quality brand names. His custom impeller wheels is enough to tell anybody that he does not know what he is doing (yes I actually spoke to him years ago).
