The chirping has returned!!!
After replacing the wobbling plastic p/s pulley, a worn out idler pulley, and putting a new belt on the chirping was gone for a few weeks
now it is back
did a little reading and looking around the forums .. looks like the only things left it could be would be a water pump or the crank pulley
got a feeling the water pump is fairly new (I'll have to check my stack of receipts that came with the car though)
but I get a chirp until the car is warmed up .. then it goes away
looked down at the crank pulley while it was warming up today and I think it may have a wobble to it
so my questions now are -
1) how much wobble is normal? (I noticed some posts that there is some that is normal)
2) if mine needs replacing what pulley are you guys with superchargers using?
thanks .. hopefully I can get it fixed for longer than a few weeks this time
I too had a chirp that would go away when warmed up. I replaced the balancer with a Summit Racing stock size for about $190. Installed it when I did my SC. Over 1000 mile chirp free except for them damn tire chirping
Chris
Chris
This is your problem I have chased this problem before lil wobble make chirp!!
http://www.summitracing.com/ga/parts...0033/overview/
just changed the power steering pulley and an idler pulley .. taking the supercharger off isnt bad, but getting it all shoved back in there is a PITA
how bad was dropping the rack and swapping the balancer?
I wish this would have waited til this summer .. been wanting to put a blower cam in, and since I already have to drop the steering rack and stuff to swap the balancer
if thats the case
I'm not worried about the noise .. it goes away once its warmed up
just dont need the crank coming apart .. thought I saw a few posts saying they can come apart and tear things up .. even though its barely a wobble if there is one (going to get a good flashlight and double check tomorrow)
just got done with the targa conversion so I was hoping to let my wallet cool off a little before starting the next "project"
if thats the case
Awesome .. I'll wait til I'm ready to do the cam then
It just started so I guess I got some time .. Has a brand new belt on it but I'll keep an eye on the belt condition and the wobble
Should be doing a cam this summer
The balancer I bought was SUM-C2501. Others have also bought it and it works great. I would also agree with others about swap. I ran my squeak until I had to pin the crank for the SC. Then swapped it out when I had to pin the crank. Many would say do the pump and chain while in there. I had no issues prior so I left that stuff alone. If I were doing a cam then sure I would have done that stuff.
Chris
Chris
Chris
Chris
car has 120k on it .. runs awesome right now, but might as well freshen everything up while im in there and see how many miles I can get out of it before it blows and I have to build it
septic tank backed up yesterday .. popped the lid today just to make sure it was the septic tank and not the foundation drain flooding the yard .. its the tank, so hopfully I can get this issue sorted out for cheap so it doesnt hold up my cam swap
Hey man I had been dealing with the same chirp! Do not wait to replace that pulley or at the least don't drive long distances. I had a bad idler pulley replaced it and the chirp continued. I started throwing belts which came down to the crank pulley failing leaving me stranded and left towing my car home. The timing cover crank seal went with it dousing my whole engine bay in oil. Lesson learned for me.
Before you replaced few pullies, did you check for bearing play noise with each pulley spinning by hand? ofcourse after removing belt.
You cant spin crank pulley by hand, but you can use medium size pry bar behind the pulley on corners and try to pry at different spots.....this gives you idea of external pulley (outer layer) moves means separating from inner pulley.
If I throw a belt then I'll park it til I fix it
As for spinning the idlers .. I did .. The one I replaced was original and really worn .. The rest look brand new and probably done with the supercharger about 15k miles ago
As for the crank I didn't check it .. Didn't know to pry on it and check
Installing new balancer on my Nissan Maxima DD as i am typing this, well it literally separated, once i took off balancer bolt out, and give a light smack on balancer both inner and outer ring fall off, i had chirping on this car for long time, and finally decided to take care of this as weather is not too bad here this weekend, good thing belt never broke on me.......so check the balancer without belt, pry on each side and watch if out ring seperates from inner even slight play there.....thats enough to call for a new Balancer.
I might be able to take the tension off of the belt enough to check the crank pulley .. Might have to do it from below though
My car has the brake thing on one side and the blower on the other side so it's hard even trying to see the crank pulley no matter prying on it from above
as for the chirp .. it didnt do it today
I bought and installed and pinned the Summit C2501 like Cutlass did. 8,000 supercharged miles with no wobble or chirps. It is an eight rib but you only use the front six. Take a look and you will see. It's SFI rated. Rod
I'll grab that one then when I do the cam and everything .. who knows I might need the 8 ribs later on
St. Jude Donor '09, '13, '15
I'm in the same boat. Chirping has returned. Last spring I replaced the top idler/tensioner and a new upper belt. Still chirped. So found out the waterpump was bad, had that replaced and the lower tensioner. The Mechanic is our area expert on Corvettes and he said my harmonic balancer was fine.
Been driving it since with no chirp at ALL and loving it. So, for winter, haven't been driving as much, but still driving it every couple of weeks. It lives outside. But yesterday I start it and it's chirping. Got it minimized some by driving some distance but still continues and more after it cools off.
Dammit.......
Dammit.......
