Fore 10 micron Stainless Filter - anyone use it?
This would be more for the custom fuel system guys in here. I know Moran makes a VERY expensive 10 micron stainless filter for the billet atomizer injectors. I just came across this though and wonder if anyone is running it. Seems like a large enough element to not collapse, and reasonably priced. Haven't seem these used in here, so thought I would bring it up.
Looks like they rate them to 2500hp, and are obviously E85 compatible. Pretty slick bracket too
I think you meant to say Moran (not Morel) ???
Comparing:
https://www.moranmotorsports.com/pro...ilter-assembly
... to this
http://www.foreinnovations.com/Produ...uctCode=16-900
And quite a price difference.
Although I'm not planning to run Q16 or E85, I would prefer to run stainless filters. It's pretty easy to find stainless on the 100 micron side (pre-pump) but not as easy on the other (10 micron) side.
I was planning to use the Aeromotive 12301 with paper for use with C16 through some Billet Atomizer injectors, but may give the Fore a try.
So, although I'm not able to answer your question (yet), I do appreciate the find
Comparing:
... to this
Comparing:
... to this
Although I'm not planning to run Q16 or E85, I would prefer to run stainless filters. It's pretty easy to find stainless on the 10 micron side (pre-pump) but not as easy on the other (100 micron) side.
Comparing:
... to this
I know for sure Aeromotive and Holley do them, as Ive used them.
Comparing:
... to this
Comparing:
... to this
Weldon makes a pretty nice 100 micron stainless for under $100.
I'm reworking some of my fuel system and just ordered one of these Fore 10 micron in stainless with bracket.
Looks like they have a pretty badass fuel setup for the top mount tanks. From Google searches it looks like they're pretty popular on Ford's, etc.
If they were before the pump/pumps, then maybe.
I run a single Holley 40 micron before each 044 pump. Never bothered with any after the pumps
JDS: something similer fuel filter Arun used on his vette, cant remember the brand or i did not pay attention except looking at that nice pretty looking piece, never saw a anodized red color exceptional quality FF before.
May be you can pm him or let him chime in.....the one you posted pretty close looking to what he installed on his vette.
Whoops, yes meant Moran not Morel... injectors, not lifters. My bad. Always get the names mixed up.
As for the 10, I'm aware of another in SS: http://performancefuelsystems.com/products.htm -- But, don't know much else about it
I'm the the process of upgrading my fuel system. We're fabricating a fuel cell that fits in the stock C5 fuel tank location with room underneath for the pump (an Aeromotive Pro series) and the pre-filter... So, with limited space, I needed a 100 micron that was not enormous and will be using a Peterson 600 series (which is SS). I'll replace the 10 paper I mentioned earlier with that Fore-10, post-pump.
I run a Fuel Lab 6 micron with an integrated check valve.
You need a 100 micron to protect the pump and 10 to protect the injectors. All fuel pumps that I'm aware of are poor suckers and far better pushers. As for the lower micron being a restriction, it is, so the fix for that is to get a filter with a lot of real estate.
But given the flow claims of most such filters...even as a pre-filter, as long as there is a good free gravity feed to it, it should be more than capable.
I opted for the -12 265gph 40micron filter before each pump.
If it can flow that amount even on the pressure side, when handling a fraction of that flow, it should still be more than adequate on the gravity side.
Of any filters Ive used, the Holley billet's are probably the smallest externally which is handy. Just slightly smaller than the Aeromotives.
Before that, I ran my pair of 044's with only a single 100 Micron Aeromotive filter for about 4-5 years. Never had any issues.
Either way, if you go big on filter capacity, you know you're safe.
Another filter option although not cheap http://www.fstperformance.com/
Packaging might suit some installs better than others. Are they just a glorified oil filter though ?
It's 9" long for lots of what I call "real estate". the nice part about it is that it tucks away nicely in the rocker panel.
"glorified oil filter"? in some cases, I'm sure they are. My 6 micron is some kind of stainless mesh. I'm running the Moran Billet Atomizer injectors on my next project and have heard complaints of the injectors leaking. The thing I've discovered is that their copper seats are soft and any small particles getting caught on that seat will cause the leak and a good post-pump filter will solve the issue.
I heard a few people say it after I bought mine and became worried. When we were at the LS fest, I noticed them on Atomic Fusion's car and had a chat with his tuner about them. He said they had a problem with them too. As I'm sure you're aware, the injectors are rebuildable and when they got them apart the seats had indentions from particles. Moran explained that the seats are soft told them to put a good 10 micron filter post-pump. Since then, they haven't had an issue.
Thanks for the posts guys. Interesting to hear what some of you run. Doesn't seem like it's a topic discussed much at all.
After dropping the driveline twice and having to drain fuel for the balance line run across them, i've put both pumps in the drivers side tank and plumbed the siphoning system back up. Had Russel stainless 40 micron filters after each pump before, but was always a little worried about them not filtering well enough. Not running E85 right now, but if I ever got the itch I wanted to maintain compatibility and have better filtration as well.
I know the siphoning system needs the check that is in the stock feed line otherwise the system will bleed down through the orifice when the pumps are off. I ran my 255 through the stock line up to the filter area (99'-02' system) and added a -6 bulkhead to the plate for my 400 to run through by itself. They Y together at in the fuel filter area and go -8 to the filter.
