pulley alignment
pulley alignment
ok guys, i decided to check the alignment again and either something changed or i just got lucky with the first 10 rib belt. i calibrated the laser with the method in brets thread and used a 48" level. i then went out to the car found its way off but im not sure how to fix it, it has me a little confused as to what it means. here are some pics/video
i see no way possible to shoot from the crank to the blower pulley without pulling the water pump which is imposible to do
video 1
video 2
video 1
video 2
To me it looks like its 1 rib off. I put a washer on each spacer that is equal to 1 rib and now laser lines up with the ridge of the very middle of the pulley which seems right to me?
im going to put a 8 rib belt if the very middle of the pulley and see if it jumps, if not ill then try a 10 rib... only problem is it takes 2 people to put a belt on and all my friends are busy and my gf isnt strong enough to hold the tensioner open lol
I just shredded my first belt and I got the dayco alignment tool which shoots a line, it's great, I found my issue was the power steering pulley wasn't pulled onto the pump shaft far enough.
