QUICK HELP - Installing A&A Kit
Old 06-08-2014, 03:20 PM
jmxp69
jmxp69's Avatar
Default QUICK HELP - Installing A&A Kit
Need some quick help guys. I'm installing my v3SI and got to step #4:
4. INSTALLING THE OIL RETURN FITTING
(NOTE: This entire section applies ONLY to the standard “engine oiled” units. For V3 “self contained” units, please go to step 5.)
Step 5 says the oil feed line requires a "provided fitting and washer". There was a fitting attached to the end of the line, but the SS line wouldn't screw into it, it's a vent fitting. Vortech provided instructions for use on the SC itself.
Here's the feed line that came attached to the head unit.
I can't find a fitting in any of the hardware bags like the one on the other end of the line already on the head unit. Also, if this is a self-contained unit, why is that line needed? I would have thought it would just be capped off.
I don't want to lose the day. Please help.
Thx
Old 06-08-2014, 03:30 PM
JT FRC 00
JT FRC 00's Avatar
Thx
On the self contained unit that SS line is for draining the oil in the unit. Just run it down & maybe ziptie it out of the way.
Old 06-08-2014, 03:42 PM
jmxp69
jmxp69's Avatar
SWEET! Thanks for the quick reply. I thought it was weird to have a line connected to the block for a self-contained unit.
I think A&A needs to update their instructions. I PM'd Josh already.
Really appreciate the help, I was a little nervous about losing the day. Back to work
To QUICK HELP - Installing A&A Kit
Quick Reply: QUICK HELP - Installing A&A Kit
