Wideband Setup
Wideband Setup
Anyone used this wideband:
http://www.fuelairspark.com/fas/dyno...al-sensorhtml/
Any opinions on it? I have a chance to get one at a significantly reduced price.
Received 1,762 Likes
http://www.coloradospeed.com/ngk-pow...or-p-6575.html
that is our most popular now
http://www.coloradospeed.com/innovat...it-p-6221.html
followed by this one
http://www.coloradospeed.com/aem-dig...go-p-4285.html
all of them work great
Ah, I didn't realize you had it. I thought you were just commenting in general about FAST products. So no issues with sunlight? Do you have it mounted permanently (photo)?
I was surprised at the low sampling rate of 12 Hz (LC2 us also 12 Hz). Aren't there 400 events / sec at 6000 rpm?
After finding a loose injector wire that was not immediately caught through a single AFR in the X-pipe (but found through dual channel data logging), I pulled the 02 sensor in my X-pipe and am changing the gauge over to a dual AFR readout that will use the same 02 sensors in each bank as my ECU is using / logging and display both.
On the dual
On the dual
You would not have noticed it soon enough at a high rpm honestly.
innovate does have an OT-2 setup that is top notch. wireless. SUPER badass.
http://www.ot-2.com/
http://www.coloradospeed.com/innovat...e-p-14219.html
ill have to check on their dual wideband option, but i thought i heard they were adding it.
I had this in my turbo Chevelle, and it worked flawless. I did have it somewhat inset in the dash and had it held by Velcro. It's very readable in the day time, and it's just perfect for brightness if you make passes at night.
In this shot it's to the right of my tach.
Hope this helps some.
[/URL]
[/URL]
