Installing an aftermarket fuel pump.
i just took out almost this exact set up. i had 60lbs injectors, boost a pump, and a walbro 400 , no modification to the bucket at all, and with a alchy kit make around/over 650. i also ran out of fuel on this setup. Course this was through the stock regulator so take that into cosideration.
So the walbro 400 crapped out on me, good opportunity to build a dual hanger or switch to walbro 450. I haven't decided which. I'm searching for a 97-98 fuel rail so I can run a return style system. It's like trying to find a live unicorn...
#39
aftermarket fuel rails are pretty inexpensive now days, just say'n
