Man my car sucks 67/66 27lbs only made 701rwhp!! I'm doing it wrong!!! Keep up the progress Ben! Lethal FTW! I'm not worthy!!! Only maps I used were the ones showing me where Rockwall is ha ha ha!
Looks awesome man. I was sad to see the stock bottom motor let go last november but I must say you have come back without holding anything back. Can't wait to see the results man. The compressor flow talk etc is a bit over my head but I am starting to slowly learn on it more which makes this build all the better for myself and other members in the corvette community.
Keep it up
I agree. The stock motor stuff was cheap and easy and worked well. I was disappointed at first and then excited about the new build. Then you start looking at all the time and effort and dollars that goes into a build and there are mixed feelings. The fun part has been learning the technical stuff and trying to put together a good combination. The best part will be driving and racing it again and hopefully participating in a larger variety of events.
Originally Posted by venomws7
Some great info in this thread thanks for sharing guys and best of luck with the remaining work Turbo-Geist.
Thanks and glad the information is helpful.
Originally Posted by JMBLOWNWS6
Just put it together allready. LOL No one cares about the *** *** compressor maps. 6266's 21 PSI 1239 rwhp. My new setup will have the same kit just better parts and ECU. You will clear 1200 EASY! Now cut the science and start wrenching.
I hear you. It's tough waiting to finish the build, but I've been stuck working almost everyday at work since July 7th. I have some time off planned and hope to get the bulk of the parts installed. I'm currently making a list to make sure I have everything to prevent any last minute part runs or overnight deliveries.
When is yours going back together?
When he gets time from fishing LOL! True story too lol! I feel you JM gotta take a break from the hobby sometimes or you just get burnt out.
I finally got a little bit of time to do some work. I started off re-shaping the ports on the manifolds to better match the shape of the LS7 exhaust port.
The rest of the available time was spent wrapping the manifolds and mounting the turbos, feed lines, and drain lines. Hopefully I'll get a chance during the week or this weekend to install the engine.
