Finally joining the FI club - ECS kit on its way
So its about time I got off my *** and went FI, I sold off some NA/Nitrous parts and ordered myself an ECS kit. Matt @ FSP hooked me up and I am getting a ECS 1500 kit in matte black
Here is a break down of my plans, aiming for spring to be completed (staying NA rest of summer until the snow falls)
Then I guess I'll powder coat my valve covers and coil brackets to match the blower for ***** n giggles.
Already have a built trans, hardened output shafts, mantic twin.
Poor mans drag pack (z06 17" with hoosiers and M&H runners on GTO spares) for track and R888's for street.
Just waiting on that bad boy to ship and I'll post some pictures, pumped to say the least
- ECS supercharger
- ECS meth kit
- LPE pump (255 IIRC)
- Martin @ Tick spec'd cam to replace my current cam
- Already have AI ported heads with 65cc chambers
- Head studs
- Would like to ceramic coat my headers black and cut off air provisions
- Racetronix hot wire kit (http://www.racetronix.biz/itemdesc.a...WH-007&eq=&Tp=) with boost a pump connector (http://www.racetronix.biz/itemdesc.asp?ic=PBIC-001&Tp=)
I wanted to know the same thing and i found this thread--
http://forums.corvetteforum.com/c5-f...ls6-block.html
Thanks it was fun wish I could do it again just because..As far as the HG honestly I don't know never pulled the heads off or looked, I let you know after the motor goes kaboom
I got the drag pack a few years back, pieced it together. GTO fronts and then got the 17's and added tires.
1500 equals a T trim and should keep me happy for a little while lol
Thanks for the laugh, although I hope that doesn't happen to you (unless of course, you're looking for an excuse for bigger, better, faster....)
Sounds good man, just thought did you bought those drag pack from me? if so they are great and only 3 runs on those tires period with no burn out, thats the day i got exessive blowby and came home.
Is ECS 1500 is equivalent to Vortech S trim? if so than change to bigger head unit....cause you will in future...lol.
More PSI than my stock short block can handle no doubt. Once my "base" FI build is done and used thoroughly I will save to forge the internals but that is a while off. Still need to collect parts for this build, hope my kit ships from ECS soon
I would really like to attend a 1/2 mile or full mile event after this setup is complete.
