new build thread, blower to TT
#342
Thanks bud, I hope so to. We still have a couple
Months before its to cold hopefully. Supposed to be a nasty heat wave coming thru this week
#346
actually just did a quick wash and some tire shine lol. i had the car detailed before the engine blew so didn't take much.
final numbers 757/786 on 14-15psi i think it was. he was having issues with my plug wires and having a hard time getting a reading for the dyno... never turned it up either, ran into issues with my coil relocation so I'm working on getting ls7 coils and short wires and different valve covers. not going to worry about turning it up for a bit... I'm just going to enjoy it for the rest of the season as is.
the turbos spool insanely fast, it makes peak tq around 4200rpm
#348
I actually fight with my wires/ohms etc etc quite a bit as well.. I recently switched to Taylor 9mm/25 ohm wires and they are leaps and bounds better then the MSDs I have been fighting with for 2 years. They actually click on the plug securely and you can get them off without them coming apart. My wires are 2-3' long with the coil relocation and highest wire was 90 ohms. Cured a lot of my misfire issues.
I'm also with you on not turning it up and pushing it hard. I'm joining the "less is more" class....when your tired of dumping tens of thousands in your car every year, this is what happens.
#349
I'm with you on all points bro...
Car is back on the road, passed emissions this morning and I was able to renew my reg right online which was amazing lol. New valve cover had -12 nipples welded on and are at the coater as we speak. Said they would be done in a couple hrs. I also dropped my 15's off to get the new Mickey II installed.
#350
Yea mine are like 45" long lol, I've always fought with them. I have morosos right now, they are a great wire and do the same thing, click when you install but I guess it's just time to fold and put them back on the valve covers. Should be pretty easy to sell the setup I have, just not for a big power car.
When I had my 5th gen camaro.
I relocated the coils and used a set of msd car wires with different boots.. And used e85 with 13.67:1 compression.
Car sometimes seemed like it had a little miss.. Had to keep fresh hot plugs in it, it always seemed to foul plugs easily, especially the colder ones.
Similar setup in 2 of my other cars never had the same issues.. Plugs heat range didn't matter as much, and didn't have to keep them nearly as fresh. And I'm talking similar displacement, similar cams, comp, and heads.
I always think to myself that the long wires made them more sensitive to issues and interference..
#352
Absolutely they will.. Apparently these coils are weak sauce and even the slightest resistance will cause misfires under boost.. Even just the end connectors will spike the resistance. I buy MSD super conductor wire by the spool and ends by the dozen... Seems like every few times you pull em off for plug checks, they start acting up. I'm hoping the Taylors do better. They definitely click on MUCH better and have less ohms per foot. Time will tell. I don't even use the heat socks with these.. Much better fit and appearance.
#353
#354
yea i used to run msd aswel and made my own wires. ordered it by the roll and probably still have a **** ton sitting around. tuner was never able to get a reading with them on the dyno. i switched to these morosos and they worked a little better because he was able to get a reading for a bit but once he went to turn it up they just sucked. I'm not going to mess with them anymore, ill just use the holley covers and ls7 coils. should be good to go
#355
Sucks. But I had so much **** under the hood of my 5th gen I felt I need them them.
#356
What is the part number on the valve covers? Is there anything special that has to be done to run LS7 coils on a C5?
Also, what plug wires are you planning to use?
#359
Looking good and hoping everything is lined out the way you want it soon. It will be nice to just enjoy all the work that has occurred.
-12 bungs welded on, then had a local shop coat them.
the ls7 just plug in, you just need the ls7 harness and it plugs directly into the stock c5 harness.
with the holley covers and ls7 coils the front coil on the driver side cover won't fit with the provided bracket due to the alternator so i just used 1 hole to mount the coil... should be fine. car started right up and drives great. i just used the msd wires. with how short the wires are i really don't see any issues with anything. i bet even stock wires would have less resistance then my long *** ones for the relocation lol.
this is the new setup, its hot as hell here so i only took the car to the hardware store earlier. the turbos pretty much insta spool lol. thing is ridiculous. the tq hits so hard with just 1/4 throttle.
#360
i actually have 3 catch cans on the car. 2 breather cans and and closed can on the head.
id have to look and see what brand the cans are, its been so long
no hard piping forsale here lol
