Opinions on these plugs and gap
Hey guys, just wanted to double check with my fellow techies. Always open to more knowledge.*
On my vortech blown LS3, just went from 9psi to 12 and switched to e85, 700rwhp. Therefore i swapped out the ngk tr6 for br7ef (tr7's). Gapped out the box at .025.
__________________
__________________
__________________
__________________
You will likely get many different opinions on gap.
Cool. That's what I figured. I guess after a couple of pulls on the dyno I'll be able to read them and be sure.
ISIS SUCKS FAT CHOAD
play around with it for sure. You may find that the car likes a smaller gap. If you want to get a good reading (especially at WOT) put new plugs in, make a pull and then check them out. It shouldn't take more than one pull to tell you what you need to know.
