magnacharger running rich i need help
hey guys
im new to superchargers just picked up a 2002 vert with sc on it car had bad fuel pump on it.Car has alot of goodies.I bought the car not running fuel pump was bad.we replaced the pump car started right up.idles fine driving it runs rough cant determine what the boost is set at i feel the power start to come on but its breaking up.im in tampa fl does anyone have any ideas this is so new to me
hey guys
lots of good tuners in the Fla area, you need to get the car looked at as it sounds like there are issues
good luck! supercharged corvettes are awesome once set up
hope you got a good deal
Jeremy Formato. He is a supporting tuner on this site and is located in Tampa. I'm sure he can get your squared away. He is one of the best.
https://www.corvetteforum.com/forums...jjformato.html
http://www.fasterproms.net/
You could have an issue with the O2 sensors or the injectors are not set up properly in the computer. If the car wasn't running when you got it, who knows. Someone might have changed out a bunch of things trying to get it to run. So the tune could be really off.
I would check your spark plugs and wires too just in case.
