looking to upgrade my pcv system
from stock sts
any advice ,recommendations, would be much appreciated
thanks in advance
I installed a belt driven vacuum pump. It is probably overkill and at some point I will need to refurbish the pump, so further maintenance, but it maintains negative pressure in the crankcase over the full RPM range.
