goes rich and sputters
Old 09-21-2014, 05:19 AM
Rkreigh
Rkreigh's Avatar
Default goes rich and sputters
well, this car is telling me it wants TLC
after a hot start, the car is running down the road and when I give it just a bit of gas it's going full rich WB is reaching 10-1
car sputters and finally recovers
I did have a code indicating the 02 wasn't heating up, but it didn't seem to cause any problems and the car ran fine. the code kinda comes and goes, car only has 34k miles on it and it's a relatively fresh ttix build
car is driven regularly and this is the first problems I've had with it running rough
time for new 02 sensors? it seems like it's having problems transitioning from open to closed loop, maybe the 02 isn't heated up properly.
any advice on how to tackle this?
Old 09-21-2014, 09:25 AM
NukeC5
NukeC5's Avatar
Sounds more like spark plugs to me judging by when you say it happens. Just my hunch though. Misfires would cause a rich condition, not sure about that code though.
Old 09-21-2014, 11:17 AM
danieloneil01
danieloneil01's Avatar
CEL for the O2 heater for the precat and on the same side as the WB sensor? If so just replace both of the precat ones and bam problem solved.
Old 09-21-2014, 03:31 PM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
With all due respect, misfires don't cause a rich condition. They cause a lean condition. Unburned fuel is just that. It's unburned. 02's don't read unburned fuel. They don't read fuel at all. They read oxygen content and for that reason, when a cylinder fails to properly or completely burn the fuel, it results in additional oxygen being pumped into the exhaust and reflecting a lean condition.
Ron, I'm guessing that your car wasn't tuned in open loop and now that the 02's are not working properly, they're not correcting any deficiencies that exist in the tables. When they're working properly, that feedback is used to correct these deficiencies in the form of fuel trims. If what I'm saying is true, once you get them working, you should notice elevated fuel trims when driving under the same circumstances that currently cause you to be rich.
Check the easy stuff first. The 02 heaters must be fully operational for the 02's to work effectively. The fuse for both heater circuits is in the block, under the hood. Check that first.
Old 09-22-2014, 06:23 AM
Rkreigh
Rkreigh's Avatar
thanks! I'm with you all and pretty sure the O2 preheater is bad
car is stumbling until it goes closed loop and the heater isn't warming up the 02 as fast
time for new sensors!
Old 09-22-2014, 08:25 AM
Supporting Vendor
As long as you checked the fuse that drives the heater circuit first.
To goes rich and sputters
Quick Reply: goes rich and sputters
