New best everything (1.26 60')
Old 09-28-2014, 10:06 AM
Shoaf85
Shoaf85's Avatar
Default New best everything (1.26 60')
Finally got the car all sorted out and took the car to a local import/domestic race for some more track tuning.
Car is working very well and I couldn't be happier.
I am still on a very conservative tune (E85 11.3 AFR/14* timing) considering this engine is on stock internals.
For those not familiar with build it is very simple.
LS3 with custom cam, valvesprings, ARP headstuds and rod bolts (thats it)
Custom return style fuel system for E85
Front mount turbo (cast wheel S480) setup fabricated by my borther (RLZ Engineering)
RPM powerglide and 9" IRS conversion
Looking over my data logs showed 11 psi on the first and fastest pass of the day.
The time slip below is the 1st pass off the trailer right after the track was prepped. I tried turning the launch boost up a couple times which resulted in tire spin. They never resprayed the track only drug it a little bit so I couldnt work on increasing the launch.
Best passes were both on 8psi launch and 11-12psi down track!
Here is one of the 5.7 passes we got on film 1.30 60' here!
Here is a cool video that my brother took with his phone (I know we are hi tech right LOL) so we could see what the rear suspension/tires were doing on launch.
Old 09-28-2014, 10:22 AM
SilverZ06NC
SilverZ06NC's Avatar
That thing is moving for sure!!! Badass car
Old 09-28-2014, 10:37 AM
Corvette0096
Corvette0096's Avatar
I would kill for that 60'
Old 09-28-2014, 10:52 AM
LSOHOLIC
LSOHOLIC's Avatar
Congrats !!
Its only going to get quicker....enjoy the ride.
Awesome setup.
Old 09-28-2014, 10:56 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Congrats!
Old 09-28-2014, 11:04 AM
Shoaf85
Shoaf85's Avatar
Originally Posted by LSOHOLIC
Congrats !!
Awesome setup.
When I get some more time for testing I will for sure go over some mid range details we were discussing. Maybe I can drop that 330' another tenth or two!
Old 09-28-2014, 11:23 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Holy crap that's moving out! Unbelievable!
Love the slomo launch video.
Old 09-28-2014, 11:40 AM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Congrats man! That thing is flying and it doesn't even have any boost in it yet. Put it on 15psi and shoot for 8.50s on stock bottom end.
The car is very efficient as it sits, I can't wait to see it turned up. Did you weigh it?
Old 09-28-2014, 11:44 AM
4DRUSH
4DRUSH's Avatar
Congrats on the new PB's
Old 09-28-2014, 11:52 AM
Shoaf85
Shoaf85's Avatar
Thanks guys for the words. I went by scale to check weight but they had already shut it down. I will get my brothers corner scales soon to weigh it.
Before I removed a/c and added turbo setup it was 2950 w/out me. I'm guessing it picked up approx 100lbs.
Old 09-28-2014, 01:35 PM
CamminC5
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
That's awesome man!!! What app was used for the SloMo?
Old 09-28-2014, 02:26 PM
Shoaf85
Shoaf85's Avatar
Iphone 5 has that built in, Ive never used it my brother did it.
Old 09-28-2014, 02:51 PM
winters97gt
winters97gt's Avatar
Holy chit that thing is moving! Isn't this only your second track outing?
Old 09-28-2014, 03:13 PM
Shoaf85
Shoaf85's Avatar
Correct sir. I'm still debating how much more if any I'm gonna turn it up lol. I know there is a little bit left in the launch and 330' but in the topend I don't wanna stress it with much more boost.
Gonna have to wait a little bit for it but I can't imagine what this car would do maxing this turbo out (roughly 400hp left in it)
Old 09-28-2014, 09:18 PM
Chris Stewart
Chris Stewart's Avatar
Outstanding! Share details on the suspension setup? I see the pfadt rear bar. The slowmo looks great, no drama coming off the tbrake.
Old 09-28-2014, 10:02 PM
b16gsr
b16gsr's Avatar
WOW love it, congrats, it is all working.
Old 09-28-2014, 10:49 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Awesome outcome with such little track time on the setup
To New best everything (1.26 60')
Old 09-28-2014, 11:14 PM
winters97gt
Damn, that thing is 600 pounds lighter than my C6. Glad you never ran the 1/4 in your C6 M6 carso my record still holds. That's an 8 second car the way it sits. Awesome!
Old 09-29-2014, 05:50 AM
Rkreigh
Rkreigh's Avatar
E85 and good tuning seems to be the secret sauce for getting these turbo stock blocks to hold up
amazing!
how much was the RPM PG setup? what else have you done to the suspension? those tires are flat out hooking!!
Old 09-29-2014, 03:51 PM
Shoaf85
Shoaf85's Avatar
My 07 C6 only weighed 3150 with the turbo kit installed and NOTHING removed at all. It was a base C6 though!
amazing!
PG setup is around $9k depending on internals used. They only make the conversion for C6Z/ZR1 diffs or a 9" which requires a shortened torque tube as well. My PG/9" setup was just over 15K in parts from RPM , not including torque converter or shifter setup. But its what I felt the car needs to be reliable and consistent.
Suspension is pretty basic:
front sway bar removed
Pfadt Rear sway bar
Pfadt Gen1 Coilovers w/ eibach drag springs up front
The 15" wheel conversion and the ET street radial pros finish it off which IMO are the most important piece of the puzzle
Quick Reply: New best everything (1.26 60')
