Good day with my little 408 ysi
Old 09-30-2014, 08:44 PM
blown81bu
blown81bu's Avatar
what dif is in that car?
level 3 rpm stock c5?
was that off idle when u left?
Old 09-30-2014, 09:26 PM
c5mtl
c5mtl's Avatar
built 3.42 and left at 1700 with only 15deg of timing need to bump it up to 23-24 to see how the car leaves
Old 09-30-2014, 10:04 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
That's gettin it man. Congrats!
Old 09-30-2014, 10:26 PM
blown81bu
blown81bu's Avatar
guess we got the same tire and dif so im not so worried now
car is bad ***
Old 10-01-2014, 12:10 AM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That's phenomenal man!
Thanks,Matt
Old 10-01-2014, 12:15 AM
mdaniel
mdaniel's Avatar
Originally Posted by Rkreigh
150 plus is a great mph!!
That's a solid MPH for a 346 ci motor with small turbos.
A 400+ ci motor with a big blower, not so much.
One of our local TTi X cars with a 346/LS1 heads/stock turbos/downpipes ran 148 MPH on race fuel nine years ago.
Old 10-01-2014, 02:53 AM
c5mtl
c5mtl's Avatar
Unreal how somebody always want to spoil the party
The setup has 5 passes on it....its well on its way to a 8 sec slip in the 158-160 mph territory.
Old 10-01-2014, 04:28 AM
winters97gt
winters97gt's Avatar
"One of our local"...
Old 10-01-2014, 07:06 AM
breecher_7
breecher_7's Avatar
We have those as well...
Old 10-01-2014, 07:27 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Those dam "local cars" always make us look so slow.
Didn't mommy teach you, if you have nothing nice to say, best to say nothing.
Old 10-01-2014, 10:30 AM
c5mtl
c5mtl's Avatar
I'm not sure what 148mph has do do with 155+
Old 10-02-2014, 03:26 AM
Y2KRoadster
Y2KRoadster's Avatar
Thank you for this. I have not read a post this ignorant in a really long time. It just proves that there are still idiots out there that talk out of their a$$.
Old 10-02-2014, 07:00 AM
  #33
blown81bu
blown81bu's Avatar
LMAO turdbo...bad *** pass....5 passes and 155
Old 10-02-2014, 04:34 PM
  #34
Ksths2
Ksths2's Avatar
Great setup & times!!
What are you using for fuel? and fuel system?
and what for computer? GM, Holley? etc.....
Subscribing!
Old 10-02-2014, 08:56 PM
  #35
c5mtl
c5mtl's Avatar
Subscribing!
I could probably run on pump gas but don't want to risk it so I run on c16 80% mixed with pump gas 20% and spraying meth...fuel system is a loonies double pump with 100lbs injectors stock gm ecu with 2 bar os should move up to a 3 bar but everything is working well.
Old 10-06-2014, 04:06 AM
  #36
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Man the 400 cubic inch engine and YSi combo is so simple yet so potent. Great job!!
Old 10-06-2014, 09:34 AM
  #37
Arun@Dasilvamotorsports
Supporting Vendor
Arun@Dasilvamotorsports's Avatar
Very nice, congrats!
To Good day with my little 408 ysi
Old 10-07-2014, 07:33 PM
  #38
c5mtl
c5mtl's Avatar
just wondering ....any suggestions on how to reduce wheel slip on 1-2 shift? at least tune based? im sure suspension changes would help but not possible for this season
thx
Old 10-07-2014, 07:36 PM
  #39
realcanuk
realcanuk's Avatar
St. Jude Donor '13
thx
Louis. If the trans works anything like my 6L80 you could try putting in a bit of torque management. It will pull some timing just on the shift.
Old 10-07-2014, 08:50 PM
  #40
c5mtl
c5mtl's Avatar
That's what I was thinking of doing or maybe try shifting a little earlier on the 1-2
Quick Reply: Good day with my little 408 ysi
