Twin Turbo C5Z
Old 11-29-2014, 07:24 AM
  #41
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Sweet, please keep the updates coming
Old 11-29-2014, 06:42 PM
  #42
jimbos'ss
jimbos'ss's Avatar
Definitely will.
Finished both catch cans today and perforated the tube in the first one. Pulled out the first one and it was clogged with oil and water sludge. Yup you were right Jon. It seems turbo seals don't like crank case pressure....hoping this fixes my smoking turbos lol.
Tomorrow's project is switching from a Tial style BOV to a Synapse synchronic one. Hopefully I remember the pictures.
Old 11-30-2014, 01:20 PM
  #43
jimbos'ss
jimbos'ss's Avatar
What a huge improvement this little guy had on my driveability at part throttle. Completely cured the surging issues I was having. It's incredibly responsive to the vacuum signal.
I had the wrong adapter so I had to weld on an aluminum vband flange to make it work.
Old 12-01-2014, 12:52 AM
  #44
JDS99
Support Corvetteforum!
JDS99's Avatar
Originally Posted by jimbos'ss
Definitely will.
Hey, glad to help catch it early!! Quit messing around and post up some videos!
Old 12-01-2014, 09:36 AM
  #45
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Really nice build!
Thanks,matt
Old 12-01-2014, 06:30 PM
  #46
red 99 first vette
red 99 first vette's Avatar
Default sd
Finally got around to doing a couple of pulls on the highway. I'm still about .05 lambda to rich in most areas. The maf maxes very early in the pulls so it's time to switch to SD or lower the boost. Blowing oil out the seal on the turbos. Pretty sure the crank case isn't nearly ventilated enough and it's pressurizing the center cartridge of the turbos. Other than that, she's a beast and i'm starting to have some fun with her again.
how about putting a 2 bar map rather than changing to SD then u will still have the advantages of the mas ? looks awesome keep us posted
Old 12-02-2014, 06:17 AM
  #47
jimbos'ss
jimbos'ss's Avatar
I'll get one up this week, was fighting a misfire issue. Seems plug wires don't like extreme heat
Originally Posted by madmatt9471
Really nice build!
Thanks,matt
Dude, I grew up in Lancaster. Just noticed where you're from. I used to run a metallic red 3rd gen Z28 back in the late 90's.
The maf maxed so early, my only option is to switch to a slot style with a larger diameter pipe and hope I don't lose too much resolution. I already have a 2bar sensor, so it's easier for me just to pop it in and license an SD tune.
Old 12-02-2014, 06:29 AM
  #48
Rkreigh
Rkreigh's Avatar
I used a big 10 AN hose vented each valve cover to a puke tank near the firewall.
my big problem is the smell the venting works though!
I'd mount the puke tank further up front to get it away from the AC vents
congrats on getting it going, been following this for a while!
Old 12-02-2014, 08:07 AM
  #49
slow ride
slow ride's Avatar
Smell is a big reason to get it out of the way. Some pull the blow by into the inlet/s, but it's never 100% clean air and ends up getting oil in the pipes over time. I put my breather tank very close to my drivers side air filter inlet to help suck some of the stink away under boost. I still use the check valve style PCV valve in vacuum to help keep the oil cleaner.
Old 12-02-2014, 07:09 PM
  #50
jimbos'ss
jimbos'ss's Avatar
I put mine up next to the intercooler and I can still smell it!
I'm probably moving mine to where the turbo inlets are as well. The only thing I like out the current placement is ease of access for draining the can.
My last can clogged so the system was sealed for a while. There is so much built up condensation in the crankcase i've been draining the last two days. I've probably pulled 12oz of water out so far. I thought my headgasket was blown, but it's water not coolant....
Big question:
I'm estimating roughly 600whp, what gap on the plugs is everyone running for that power level?
I have one step colder than stock heat range and running IIRC a .32 gap. At idle I get a bit of random misfires, when I log it it jumps around to different cylinders, so i'm thinking plug gaps.
Old 12-02-2014, 11:26 PM
  #51
slow ride
slow ride's Avatar
Idle really shouldn't have much of a problem with large gap. It's under high boost and rich fueling that you can blow out the spark. At that power level a TR6 between .025-.030" wouldn't bother me. That gap will open over time so on a boosted car you might need to check it more depending on how much you push things. Make sure your plug wires, etc are all clear of the manifold, etc.
Old 12-26-2014, 12:10 PM
  #52
jimbos'ss
jimbos'ss's Avatar
You're right, wasn't the spark gap. I had traded someone injectors and the o-rings were leaking. Changed them out and the car runs dramatically better. Little vacuum leaks can be frustrating as hell. At least I can put it on the dyno and finish tuning now.
Old 12-26-2014, 12:45 PM
  #53
jimbos'ss
jimbos'ss's Avatar
I finally got around to building the radiator shroud. I used a sheet of 1/8" ABS plastics. I cut a cardboard template then cut the ABS and used a heatgun to form it. It seals down the sides of the IC, AC condenser and radiator.
CorvetteBrent (10-05-2018)
Old 12-26-2014, 02:12 PM
  #54
JoeyG
JoeyG's Avatar
Clean shroud, I like it
Old 12-26-2014, 06:31 PM
  #55
jimbos'ss
jimbos'ss's Avatar
Thanks, it was my first time working with plastic. I'm really surprised it turned out ok.
Old 12-26-2014, 10:39 PM
  #56
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
Lookin good Jim!!
Old 12-27-2014, 01:06 PM
  #57
jimbos'ss
jimbos'ss's Avatar
Thanks Mike!
To Twin Turbo C5Z
Old 12-28-2014, 01:08 AM
  #58
jimbos'ss
jimbos'ss's Avatar
There is actually a couple of us on here. You on FB?. We have a locals page 254 racing. My name on FB is "Ji Mbo".
Old 12-31-2014, 09:36 PM
  #59
jimbos'ss
jimbos'ss's Avatar
Template I made for the radiator shroud.
Just getting some practice in, haven't picked up the torch in a couple weeks.
Old 01-01-2015, 12:43 AM
  #60
BryanV
BryanV's Avatar
Jim your making me want another C5Z
Quick Reply: Twin Turbo C5Z
