**Keep those FI engine cool! Check it out!**
Supporting Vendor
CoolIt H2 and H3 Hard Wire kit
High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6
For those that prefer to Hard Wire the Coolit Fan Controller in, we have developed latest version of the Coolit, the Coolit H2/H3.
It operates just like the original Wireless Coolit V series, but instead of using a wireless FOB to activate the fan it uses a switch and LED light.
The Coolit H2/H3 allows you to control your C5 Corvette's radiator high speed cooling fan with a simple push of a button allowing you
to control your radiator coolant temperatures. No need to pay for an expensive tune to just to change your fans on/off temperatures.
When switched ON, the LED lights up showing you that your Fan is running.
The CoolIt H2/H3 will NOT interfere with normal computer controlled operation of your fans.
Go here for more detailed info about then New Coolit H2/H3.
Only $119.95
http://hstrial-saccitycorvette.homes...ireCoolit.html
If you prefer to go with our plug and play wireless Coolit V2/V3.
http://hstrial-saccitycorvette.homes.../COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
bad man Barry White (12-10-2015)
Supporting Vendor
Warm weather will be here before you know it. Now is a good time to install the New Hard Wire kit. We also have the original Plug and Play Coolit if you prefer.
Thank you,
Christian
Thank you,
Christian
