Need some direction.
I'm guessing this is the right place to start. I am wanting to Supercharge my 02 coupe. The motor is tired. Should I purchase a low mileage engine and start with that or rebuild and freshen up my exsisting one. It has around 190, 000 on it now. Bought it with 130, 000. I've done all my body and suspension mods and now I'm working towards the big mod. I'm treking into unfamiliar territory and just looking for some direction to avoid costley mistakes. I'm looking for hp somewhere in the mid 500's to 600's. Needs to be a streetable and reliable conversion. Not looking for a drag car. Just some fun power to play with. I'm running a Z06 3:42 differential with a 2800 stall. B&B bullets with xpipe. No headers yet. Motor is stock and tired. Will upgraded heads be needed to obtain my hp goal? Ready to absorb any and all knowledge and suggestions. Thanks Rob
Received 1,762 Likes
Trans will be your next big $$$ when you have to go with that go with RPM transmissions in here. You can really buy a build short block cheaper that you can have one build on these LS motors. Robert
Lots of opinions, most will depend on your budget, so assuming it is minimal, here is mine.
If you think you will be happy with mid 500s, then find yourself a good LS1 longblock (00 or later) with low miles (40-80,000) and just put it in and go (can put in a cam and pin crank while out)
Another approach is to get a low miles short block (cheaper) and have your heads worked (adds expense) and do the same
The most expensive, but best long term choice, is to hook up with someone like Thompson motorsports, buy a no frills forged short block for less than $3000, then work your heads, buy the gaskets, oil pump, timing chain, etc. you need and have a motor you can build power on for a while
We can definitely get you a budget friendly motor that will work great with the supercharger. Give us a call and we can get you lined out quickly to see if what we offer will work for you.
Thank you for the recommendation Blow Torch we appreciate it.
If you really will be happy with 500hp, then save yourself a lot of money, and build a stroker. No forced induction necessary, and you solve the tired motor problem. I still vote forced induction though. I would probably boost the motor you have until it just quits, unless you know its ready to quit now.
An LS3 crate engine, headers and a mild cam should get you 470 easy.
416 stroker would be 525 easy or more depending on budget.
if you want to go S/C 500/600 hp Just drop in a low mileage LS1, mild blower cam and headers, 550 should be easy for that.
Agree, Your trans would be lucky to live with just the LS3...
I went with a long block 383 stroker(not cheep). If I had to do it over I might have looked at selling car and buying a sc car from a forum member already done with forged internals etc. I put 342 rear in, then sc kit and was saving for tranny and motor went! I was in kinda deep with a blown up car so it was not an option to sell at that point plus I like verts and you can't find as many for sale here with sc and all the goodies already. Much cheeper to buy a done car than to build one from scratch, but probably not as much fun! either way good luck!
Adam
Adam
