Looks like more than the oil feed and drain lines missing unless I'm missing the adapter piece that goes in the block.
The new kits also come with a Lingenfelter pump or BAP, depending on the year, new spark plugs, a check valve for the crankcase vacuum line and things like that. I'm guessing at least 450.00 in parts missing here, only if you still have the top shroud and just forgot to include that in the pictures. It's the older blower bracket too. Still quite a bit of savings over brand new.
Hopefully you find this ^^ helpful.
GLWS.
A&A sells a kit that is the supercharger only, no fuel system or spark plugs...it's just not pictured on their website. The YSI kit with the supporting fuel system costs 8000. Feel free to call and check since you feel the need to come in here and discredit my thread.
My kit comes with all brackets and the radiator shroud. The shroud is not pictured. There is no block adapter piece missing. Maybe you should look at the pic again. The kit was unbolted from my car and moved to the floor of my garage and the pic was taken.
You are right...there is no check valve for the crankcase vacuum...anyone who runs a ysi always builds their own setup here.
The older bracket works just fine. All you are doing is trying to start $hit and discredit my thread. Everyone else that has comment has had nothing but compliments for my kit.
Please stay out of my thread unless you want to buy the kit. Thanks.
