Supercharged automatic guys hitting 1.3 60's...
Just curious for all you 9 second (or better) guys hitting 1.2-1.3x 60 foots... what is your torque converter and gear combination? Would be interested to see the brand/model/stall/rear gear that everyone is using to get out of the hole a little quicker. Currently I'm running mid 1.4 60's but looking to maximize my setup before adding any more boost. Right now the car feels like it is leaving really soft. I launch just above idle. Take a look at the video and you can see it looks very mild leaving the line. Car makes 609 rwhp at 12 psi. I'm also running C6Z replica wheels up front and don't really want to use a skinny if I can avoid it. I don't mind switching back to a stock 17" front Z06 wheel however.
Setup is as follows (absolutely no suspension mods and it dead hooks):
-E85 fuel
-ECS Novi 2000 kit with restrictor plate, 3.8" blower pulley, A&A secondary drive kit
-A&A twin pump external fuel system
-C6 Z06 in tank pump with Racetronix harness
-Bosch 1000cc injectors
-Innovators West overdrive balancer (8")
-ECS big blower cam
-Dynatech long tube headers with cats feeding stock titanium exhaust
-RPM level 6 4L60E transmission with Yank SS 3600 converter
-M&H Racemaster drag radials 275/50/17 (28") on Z06 fronts
-E85 fuel
-ECS big blower cam
i have the same blower as u( best blower out there mho) but im making 914 rwhp and 890tq..Im running 275 pros 15" in rears and 18" skinnies
no idea what its gonna run with that much power but seeing your run with 600 is god dam good
my rental is monday ..let u know how it 60 fts
i ran the car a year ago with 750hp and 19s did 1.60 60 foot 119 mph eigth 9.6 1/4 mile
i run a 10.5" pro yank 3400 converter 3.42 gear and totally stock suspension
Received 1,762 Likes
-E85 fuel
-ECS big blower cam
Supercharged Z06 on E85 at Greer Dragway - YouTube
-E85 fuel
-ECS big blower cam
A 1.44 60' is not bad for your combo at all... Skinnies will net you another .05. If you start screwing with converters, you can go the other way real quick...you'll 60' better, break more parts, lose mph.
I'm with ARUN, stick with your parts combo, work on your tune up where the converter flashes too...Ofcourse more boost is always good but...I wouldn't push it any harder then what you have it set at now.
Definitely get a drag pack for it... You'll gain 1-1.5 tenths and 2-3 mph with a full drag pack.
I have been 1.36 60' leaving at 1200 rpms and briskly pushing to the floor..(not straight up hammering). Every time I leave foot to the floor it breaks an axle. I figure it will go 1.30 on a full power/hard launch if it doesn't break parts.
I'm using a 9.5" FTI converter.. It's the 2nd FTIS converter I've had in it...also had a 10" Coan billet... The FTI is 5 mph faster.
Good info guys, thanks! I wanted to max this combo before adding any more boost. I may try adding a couple more degrees of timing (ramped) and if I do add boost, I'm going to just start with 1-2 lbs. I don't have any reservations tuning it to 650-675 rwhp. Also, a drag pack would be nice--I may start looking for one.
My car did a 1.28 60 ft yesturday first time out..u would be surprised what i have for suspension..back it up with a 1.30 60 foot..ECS knows how to tune these cars..i dont think its much to do with parts more in the tune
doug again is amazing
Please tell me someone got a video of this? I will also pick Doug's brain since I've got all my data logs.
Cars running great man. You and Charles both showing out for the local vettes. Good to see the C5 do some work on that beautiful C6 of Barbers (Hopefully he wont get to mad at me for that one haha)
Wait a minute, Doug was driving?!?! That means it doesn't count.
