Pushing the limits of a V3 Si trim!
As a few of you may know I had an issue with the last motor that was in the car...well all is good now! I am VERY pleased with the new setup, and new found power. A big thanks to my engine builder, and Mayhem Motorsports for standing behind the eng and the tune. The numbers for the "little" Si are 737/657 . Couldn't be any happier, definitely feels a lot better than before.
[QUOTE=95wht6spd;1588227177]Nice! What are the specs? How much boost?[/}
Thank you,
Stock heads & crank, Callie rods, diamond pistons, 347 with 14 pounds of boost.
Thank you,
Nice build buddy and awesome #'s!
What cam did ya stick in her?
Those are amazing numbers, congrats! What cam did you run?
Thank you
Same cam as before and mass air
Oh yeah!!
Thank you Dunn, your car is looking very good.
Thank y'all, custom grind from my engine builder.
Oh yeah!!
Yeah most people dont waste there time with the Si, but i wanted to see how it would do maxed out. Seems good so far. I hope to be getting a YSI in the next year or so, curious how just a blower change would do! But then again my t56 isnt liking life either, already built it and the diff once.
I am running meth injection, set on dial 2 or 3 I believe. They did not make the tune meth dependent. Fuel system is the LPE intake w/ the hot wire, holley 1400 pump activated by boost at 2-3 psi. I am also running the holley fuel rails with the id850's, -8 supply, and -6 return. I think my injector duty was like 68% or so. I tried to "over do" the fuel system I case I decided to go to a YSI.
s1020.photobucket.com/user/Bryanwicker/media/e5e90ab486b93d13c1f8f926a4851ff4_zps9ac5 bd23.jpg.html][/URL]
