ECS blower build
#61
Received 1,194 Likes
St. Jude Donor '15
http://www.jegs.com/i/Chevrolet-Perf...94007/10002/-1
Yeah.. def. put blue loctite on that bolt. That one coming out would be bad for sure.
#62
Jegs will ship it for free I think. $5.99 total
#63
St. Jude Donor '15
#65
Small updates - more parts arrived!
BTR push rods
2 bar MAP
ECS IAT relocation kit
This weekend I plan on:
BTR push rods
2 bar MAP
- Reconnecting tie rods / sway bars
- Installing pushrods / rockers
- Drilling intake tube for IAT and meth
- Laser aligning the belt system
- Installing belt (hopefully I don't have alignment issues).
- Wiring up new IAT sensor (solder not crimping)
- Figuring out how the shroud fits and installing it
#67
St. Jude Donor '15
Do you put the IAT sensor in the charge pipe or in the intake? I've seen some people actually put it on the intake by drilling a hole. Not sure if that's normal though.
And yes, def. solder it.. not a fan of crimps. Even when I build weatherpack or metripack connectors with the proper crimper I'll still put a quick dab of solder on them to make sure they aren't coming disconnected
#68
Also I got some new wires as my MSD's were not worth using again, heat got to them.
#69
Received 1,261 Likes
you don't have to weld a bung for the screw in style iat sensor, you can drill the hole in your pipe slightly smaller than the threads on the sensor and then tighten it into the pipe... it will kinda jam itself in the hole and you can use a dab of jb weld around the very edge to keep it sealed and prevent it from coming loose... it can also be removed with minimal effort later on if you need to for whatever reason... I would trust that more than chancing one popping out of a grommet
#71
Worked on the car for most of the day. Started off torquing the tie rods / sway bar to spec. Then moved on to the rear coolant cross over. Had to run out and get some bolts as I lost one but overall it looks decent. After that the oil was drained and we fought with the K&N filter some. The nut didn't help, I must have been on PCP when I hand tightened it last time
Pushrods and rockers followed, along with valve covers and some fresh oil. Added a bottle of Lucas break in oil additive for extra protection. Then it came time to align the laser alignment tool. We did the best we could with levels, straight edges, and the alignment sheet. Installed and torqued alternator and it was time to laser align.
Overall the alignment results were good. IMO everything is aligned but the blower, it seems to be angularly mis-aligned. The two bracket bolts near the coolant lines need to be shimmed (based on results below, any help please shoot my way).
Alternator to PS pulley - top of 2nd rib
Alternator to crank balancer - top of 2nd rib
Alternator to blower - Valley between 2nd and 3rd rib
PS pulley to crank - just the back side of the 2nd rib barely
Blower to alternator - between 1st rib and front of pulley
Shimming the passenger side of blower seems like the reasonable fix, wouldn't you think??
#72
shoot from the blower to crank and crank to blower also... you might have to remove a spacer to give the laser a clear path
#73
St. Jude Donor '15
How are you planning on shimming the blower? I bought some washers and starter shims earlier but not sure what the "right" way is to do it
#75
no problem... how accurate is your laser calibrated?... if it is off slightly at a short distance then the longer the distance you shoot from the more it will be off which will throw off your readings... I calibrated mine with a 4ft level according to the thread in the stickies, if yours is calibrated to that long of a distance then that should be plenty for any reading you could take on any of the pulleys
#76
St. Jude Donor '15
Am I understanding correctly that you are planning on basically moving the passenger side of the blower towards the front of the car?
#77
St. Jude Donor '15
Mine was remarkably close from the get go though.. the design is a bit different and is such that there isn't nearly as much adjustability as there is with the Gates unit (for better or worse I suppose)
I was measuring the difference with calipers at 48" away and operator error was > than the difference.. so I think that is about as good as I'm going to get with what I have to work with. I didn't have a nice marble counter top to work with.. but hopefully I did OK
#78
also if you think the blower has an angular misalignment it might be worth taking all your spacers off and measuring them with a dial caliper to make sure they match or maybe one was put in the wrong place causing the misalignment
#79
The blower to alternator is the farthest distance and therefore could be off a little more than others but still be acceptable.
Blower to crank is key for sure. I am in the middle of the same process and everything lines up pretty well. The blower to crank on mine was off by a little under one rib. I think that will be ok, but I guess I will find out when she runs.
#80
Thanks for the input guys, tomorrow I am going to recalibrate the laser alignment tool according to Brets thread. Then I will recheck alignment, remove a spacer and check blower to crank.
@schpenxel my understanding of shimming is just using thin washers in the correct location to push (if necessary). Then again that's just a guess because I never had to deal with blower alignments before this
