What oil for forged motor?
I have read the break in procedure for my new motor, never really thought about oil before. So I have a forged motor with cat. conv. what oil are you guys using that has the phosphorous and zinc required and not too much for the cats. After the initial break in of 5000 miles?
Thanks in advance
Adam
Thanks in advance
Adam
Received 1,762 Likes
Thanks in advance
Adam
Thanks in advance
Adam
Just regular oil has more zinc than most I also like the shell diesel oil 15-40 good for the price.
I'm running the Rotella TR6 Synthetic 5w-40 but check with the engine builder. Most recommend thicker non synthetic. Rotella 15W-40 is great for the price.
Are you running cats? Are the anti wear additives really a problem for the cats? To me the motor wear is more important but wondering if the ZDDP is really a problem. A lot of the information I read is a little contradictory as far as what is best for motor and car. Cost is not a problem, looking at what I have spent for motor. Gotta pay to play!
I run the rotella 5w40 synthetic from walmart..mobil 1 sux broke down quick on me
rotella at walmart
rotella at walmart
running Castrol 10w40 in mine
Thanks for all the input you guys! I just want to ask again if anybody? has experienced a early failure of new high flow cats using any of the specialty oils with the higher ZDDP amounts or is this all cya stuff from the mfg?
Thanks again
Thanks again
my LG cats only lasted a summer they blew apart. I don't have any now but I think it's because of my hp level and spraying methanol
