Joining the FI club!
Veteran
Hey I took my 97 in for some work. Going with the A & A blacked out kit.
Here is the base pull before any work. Just headers, vararam & a tune. 326 hp and 350 tq.
https://www.facebook.com/Cincyspeedracing
Received 1,762 Likes
welcome
Veteran
Here is cincy speeds website for my car showing it as it has progressed.
https://www.facebook.com/media/set/?...2994113&type=1
Received 1,194 Likes
St. Jude Donor '15
So what are the details?
You haven't really told us much other than supercharger..
Veteran
Engine: full rebuild, tunion upgrade, ls7 lifters, ls2 connecting rods, head studs, diamond forged pistons, cincy speeds boost camshaft, A & A's blacked out v3 si kit
Transmission is a Performabuilt Level 3 A4 with a 2600 stall
rear end is a 3.42 from a Z06
Exhaust is Kooks 1 3/4" header, 3" in X pipe, no cats, and Bola stingers on the end
Veteran
No its a Z06 badge, it was on it when I bought it back in August. I know the kid I bought it from said his grandpa put it on in 02, Once I get it back I think I am either going to put an LS1 or supercharged emblem in its place if the paint is off when I remove it. Although technically it will be part Z06 since that is the rear end I am putting in from an 03 Z06
Veteran
I got them from a member on here for 70 bucks, he has used them with up to some of his 800hp builds and they held up fine as long as you use the ARP rods bolts head studs, so I did save about 600 going this route. I was going to get a set of Callies because he couldn't find a complete set of LS2 rods, then I found them on here
The ls2 rod weighs more so are they going to balance the crank?
