Any one replanced A&A air filter with K&N
Old 12-15-2014, 02:12 AM
Moonder
Moonder's Avatar
Default Any one replanced A&A air filter with K&N
Any one know the right K&N air filter can replace the A&A blue airfilter?
Old 12-15-2014, 02:54 AM
a/c man
a/c man's Avatar
Why they are made the same nothing to gain here not much room in there to go much bigger. .
Old 12-15-2014, 03:30 AM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
What A/C man said no need to replace it.
On that note A&A has a purple colored filter. Looks like K&N but with A&A name on it.
Old 12-15-2014, 07:20 AM
redcycle13
redcycle13's Avatar
I measured my available space for the filter, then went to the K&N website and used their search by dimension feature to get a part number. Then I ordered that filter from a local auto parts store. I was able to get a significantly larger filter on my setup. I don't know if it made any measureable difference since I didn't dyno before and after. I only did it because I managed to damage my original A&A filter. I had a talk with K&N tech support during the process of looking for a filter, and they told me you can in fact exceed the flow rate of some filters with a supercharger, and that obviously hurts performance.
Old 12-15-2014, 01:29 PM
Moonder
Moonder's Avatar
Do you have the part number of the air filter?
Old 12-15-2014, 04:48 PM
redcycle13
redcycle13's Avatar
I don't remember the part number, but it may not work for you anyway. I run a Cartek bracket with an A&A inter-cooler and piping.
Old 12-15-2014, 11:35 PM
Moonder
Moonder's Avatar
Ok, thanks
Old 12-15-2014, 11:40 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
To the OP here call andy or what ever head unit you have on the car. Tell them your set up and ask them for help they have a reason for what stuff they put with each set up.. Robert
Old 12-16-2014, 07:17 AM
breecher_7
breecher_7's Avatar
If you want somthing that will really breathe well take a look at the Airaid Race Day and Track Day filters. FYI, I wouldnt use the RACE filter on the street....
Old 12-16-2014, 10:29 AM
CamminC5
CamminC5's Avatar
St. Jude Donor '15-'16-'17-'18
I'm using DP's Big Mouth Filter on a Ysi, but that's on a 4" pipe.
Old 12-16-2014, 11:07 AM
robert miller
same here.
Old 12-16-2014, 06:50 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
He ordered a replacement filter from me already.
Our SC air filters are made just like the K&N and are re-usable if you don't mind cleaning and drying them. Some of my customers like to buy an extra filter, to avoid downtime during filter cleaning/drying process.
Old 12-16-2014, 08:15 PM
CamminC5
CamminC5's Avatar
Old 12-17-2014, 09:37 AM
Moonder
Moonder's Avatar
Thanks Josh 👍
Old 12-17-2014, 08:14 PM
jbsblownc5
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
I've spoke with K&N techs as well, and I'm actually a K&N distributor. Regarding the possible choking off of air flow, too small a filter CAN cause this.
They did a simple calculation to determine how much airflow my motor and supercharger would produce, and then sold me an oversized TRUCK filter that did the job...
Old 12-17-2014, 08:48 PM
meadowz06
meadowz06's Avatar
St. Jude Donor '09 and '13
Great thread!
Old 12-17-2014, 10:36 PM
danieloneil01
danieloneil01's Avatar
Downtime when cleaning the filter? Bunch of lowjos. Just whip it around in your hand a few times and let the motor dry it out.
To Any one replanced A&A air filter with K&N
Quick Reply: Any one replanced A&A air filter with K&N
