C5Z8U ERL 429 TT Lethal Performance build
Awesome build man! What is Ty gonna do now? LOL
BTW, why no 6 bolt block? For this crazy of a build, I would have thought a 6 bolt would be mandatory..
(PS. I'm stuck with a 4 bolt myself...FTL)
Luckily I am swapping subframes with Joe Mike so all the work they did for clearance will already be done on mine. Fuel systems and everything else was already complete for blower so its really just top end of motor install and turbo kit. Which is obviously not easy work, but Lethal Performance has tons of experience with this kit so its an easy job for them
Either there or TI. And we will have to line up this time! If you do break a belt again, I'll get a new one put back on for you just like last time. Lol
Lol....I know it can be confusing.....lol.
Turbine inducer size.....not compressor.
Your 6266 says it's a 62mm compressor inducer and a 66mm turbine exducer. I'm asking about the turbine inducer size, which will be larger than the exducer (66mm) of the turbine.
#34
I'm sure precision has the specs you are looking for on their website.
#35
Thats ok man.......to many options and models to guess which ones you are running. Also Precision typically does not publish that info. Just the 62mm/66mm and a trim, but through deductive math a guy could calc the turbine inducer size.
thanks anyway..........good luck with your build.
#36
I'm all in for this build very nice stuff!
I'm slobbering over those turbos, can you PM me the price?
just got the champions and they are pricey but are almost too pretty to put on the car
I am going to try out the .82 turbo housings on the the stock TTiX turbos (58/62 I believe) for a bit more top end pull
I'm building an iron block 380 to replace my tired ls6 (forged)
I'm curious to see how those turbos will work feeding the big inch engine
should be a torq moster and still have the top end charge with the great flowing heads
very good choices on your build
thanks for sharing all the details, that cam looks really good, it's a biggin!
#37
#38
I sold everything. I'm out of the game for a while. Things changed and I ran into a good deal on property (Ranch) and I have been putting all my time into that. Car is going to be nasty brother. Ill be back in the game with either a C6 ZR1 or a C7 Z07. After going with Danny to get his C7 Z07 Im pretty much sold on that.
#39
#40
The boys at lethal have been busy. Making great progress. Car should be running early this week and on the dyno by the weekend! I'll keep you updated on numbers
