402/F1R Version 2.0 build....
#161
Awesome sauce. Interested in results of less boost/more overlap too. I had mine out for an extended test drive yesterday which went well but soon after getting back I found the power steering hose had been up against the pulley and rubbed through. Gremlin count post rebuild totals three now; brake line, oil cooler hose, power steering pressure hose. I want to take it out to the HPD/KP heavy hitter dyno night this weekend but I don't want to dyno it just yet.
Previously I had never made a hit on it with it over about 88* outside, and I only took it to 7200 (where I would see 23-24 psi, 258-260 kpa)a couple times because it ran out of steam by 6800...boost would continue to climb but HP would fall like a stone. Normally at my usual 6600 shift point, I would see 20-21 psi... (255 kpa) then thru the traps at 6900 I'd see 22-23 psi (258 kpa).
Now it seems to keep pulling and revs faster then ever after 6k.
I will be keeping my 226/238 cam in case I don't like how this big cam performs. I expected some low to midrange loss in power, maybe not this much but, with the converter, it's not a big deal, it's really never under 5k rpms when it's WOT. We'll see what the track says... That's the final ruling on stuff for me.
#162
The meet is Saturday night I'll be working. But speaking of bad luck changed the slave which ended up being the slave hose busting. installed new one and felt like I was on the down hill of my little gremlins but me and Bill cruised to Kroger and fueled up on way back something on the slave started leaking proabably on of the lines is my guess. Sucks to be me right now LOL! Between you me Bill and Bret I believe we have all the bad luck covered LOL!
#163
I'm off sat night but start days on sunday so....I won't be out too late sat night, definitely not late enough to make it to KPs. I'll likely just hit the usual spots on Friday/Sat night. We still have a lot of tuning to do on mine so I need to do some driving/logging and get the quirks out of it. Bret is pretty much handling all of that stuff for me remotely. I'm just glad to be able to get in it and go to the store or something at this point....LOL.. Not pushing my luck on anything right now. Point A to Point B.
