Z06 procharged...next step?
The current tune on this car is from j&j speed shop buffalo ny. Seems to be very good, but i live in rochester and have used new era performance on previous builds. Im not really familiar with J&J speed shop and im wondering if anyone has any experience with them?
Received 1,261 Likes
if you go that route I would get the biggest intercooler they have and not the smaller one that they offer now, just in case you want to add big power later on
Assuming you have the second version of the intercoolers, they work very well (at least in the sub 700WHP ranges).
Also if you intend road race type use, there is an advantage to leaving the dual coolers in place and not stacking an intercooler in front of the cooling system.
I can tell you in my setup with dual coolers, single nozzle meth triggering at 4PSI(progressive alkycontrol pump set low) - my IATs are at or below ambient.
So for my use and power level I see no benefit swapping to a single IC and In fact it could very well be a detriment...........
how you use your car is probably the best place to start
Yes I kinda felt the same way, I have the newer style intercoolers. I use my car for evening/weekend street races and 2 times a year at the local 1/4 mile track. Sometimes drive it to work 25 mins. I think the fmic is a waste for how I use my car.
