whats wrong with WISECO??
#41
I havent see one with absolutely no markings, but if its a totally custom piston is different than, say just changing something on a shelf piston like compression height etc... They both will be called custom. But really different if someone specs just about every aspect. If the engine builder was trying to keep it totally secret I could see them removing them. Just a guess though. I don't see why there wouldn't be some identifying marks for any other reason though.
#42
W
I have used diamonds before in my 406 sbc procharged deal and they were twice the cost of these and looked very similar..
i almost did call them but decided to follow what i seen work great in ls...
#43
#44
Go with Diamonds, call Wiesco, cancel (specially with Novi 2000)
#45
Received 1,762 Likes
#47
#51
theres been thoughts in my head to bring the car back home since it is for sale and sell the vette
#52
8.20 never broke I would, & just put the vette back to per say stock and have a nice DD with that. That vette will never see a 8.20 run after run on your set up as it is now..
#53
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
You had Diamonds in your Malibu? You mean like attached to your big glasses and fur coat?
Just kidding, bad *** cars can wear any color.
#55
#57
My piston thread turned into a G body thread
#58
can you all Pm me good POCs at Diamond or Cp bullet ?
I'm looking for pistons, pins, and rods that will handle 1k hp in a small bore 4.8 tt build
I have a lunati 4.0 crank and some 3.86 wiseco pistons but the bores in my block look good so a stock 3.78 or 3.8 bore that will work with the 4.0 crank
also like advice on what rods, don't want to spend more than 800 on the rods or pistons if I can help it!
#59
