Injector ?'s
Injector ?'s
I have a 02 z06 with full bolt ons and getting a head and cam package along with going to run a 100 shot. What injectors should i run? What brand? Im thinking 42lb injectors but idk what kind to get or where. Im hoping the car will make 460+rwhp motor and around 530 or so on the bottle. Thanks guys
Im looking for real world knowledge along with brands and what not i have the fast 102 on my car and idk what injectors to use svo or what not. Ive heard they rub so im looking for info on the topic with where to find any buy the right injectors.
Deatschwerks is definitely a good choice. Top quality injector with great customer service all tuning data included as well for great price. I run them in my car on E85 with stellar results.
Cruise-In IX Veteran
Are you running a wet or a dry shot?
I would suggest going with the LS3/7 injectors. They are a good swap on the C5 with some wiring adapters and height adapters.
Ok i want 42 lb injectors i have a FAST 102 with the FAST fuel rails. Its a ls6 Im looking at two injectors.
Fast 42 lb injectors
or
Bosch 42 lb green giants
which one you guys recommend?
or
I would expand your options. With injectors you want some with good data. I would suggest sticking with a GM injectors used in another application. If you want almost plug and play, there is a white injector from the 2001 Pontiac Grand Prix Supercharged. It is identical in dimensions to the stock Ls6 injector, but flows 42 lb/hr. Other wise, I would go with the stock Ls3/7 injectors and the adapters required to run them.
