Vis carbon fiber cowl hood?
Got my hood weighed myself on digital scale then weighed again holding the VIS hood 33.5 pounds difference. Did the same thing with my stock hood, 33.5 pounds.
My point was, a true CF hood should be lighter, like 20 pounds lighter
Post a pic of your new hood.
I had to notch mine to clear my Edelbrock Pro-Flo intake and added heat extractor vents to it. I still like the looks of it and quality after hacking it up.
The 4inch carbon fiber cowl. No heat extractors. Drag racing was fine but put me on edge at the end because you could see the hood raising and flexing due to the air speed and pressure at 125mph. When I run 1/2 mile airstrip races I switch back to the own hood for my own comfort due to a lot less flex. I remember an article in gm high tech years ago of a participate running a cowl carbon In a top speed shoot out which pretty much Disintegrated during a sub 160 run
Here is the pic you requested.
Trying to link pics with my phone. I cut the rear cross brace and installed a support bridge to clear my Pro-Flo intake. Then I added Runcool extractor vents to the cowl sides
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Damn, that hood looks great... I sure wish I was confident it would clear my new setup.
VFN sunoco hood is on the way...
