Ecs tensioner?
Received 1,261 Likes
Ecs tensioner?
just wondering if anyone knows who makes the tensioner that ecs supplies in their kits... long story short mine broke and I need a new one... I remember someone had posted the part #'s maybe a year or 2 ago but that thread was deleted... feel free to pm me if you don't want to post publicly and thanks for any help
the 3/8" hole that is used to open it developed some small cracks around it that progressed down into the webbing of the body... had it welded up and put it on a bench to make sure the weld would hold and that it actuated properly and a big chunk of the case broke off the bottom... pretty sure it's toast
I tapped the alum Hex piece & used a longer bolt, then had it welded.
Works super easy & you wouldn't break that
yeah that looks like a great solution, wanna sell me one of those?
clever Jay
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
Two issues I see, welding aluminum weakens it unless it's reheated, and we machine the tensioners to fit the kit.
GLWI.
GLWI.
pretty sure I found it, $40 tensioner and the machine work looks like nothing but grinding some material off of the body so it will clear the rack, thanks
Other side is also machined which is for the idler hold down so it needs to be precise. You have the old one so it shouldn't be hard to have a machine shop do that. We made a jig for the Bridgeport but it shouldn't be hard to make a temporary one.
ISIS SUCKS FAT CHOAD
Just wanted to post in this thread. After seeing it and talking with Bret, we decided it was a good idea to do like Jay did and weld a hex head on it.
Thanks for the idea Jay and thanks Bret for welding it up for me.
that looks familiar... in case anyone else is interested...
In the pic I have the AC tensioner and idler pulley on wrong. I realized it after looking at it. I had to go reference the ecs installation instructions.
And yes, they're most certainly ford tensioners. I bought mine from ecs though through arun because I needed the spacers and pulley Ect for a 10 rib and because I had already spent the money by the time I found out what it was. :-). Arun did me a solid on the price.
Did you change your set up?? I thought your car was done, where you were satisfied with your built or did i miss something?? Just curious.
top one is the original tensioner I had, bottom one is the new one before machining... obviously it will be easier for the machinist to match it up if you have the original but even if you didn't have one I'm sure they could get it done as long as you have an idler so they have a point of reference... also notice there is not enough material on the tensioner to support both bearings in the idler so only the bearing nearest the front of the car with the tensioner installed will have support and the other bearing has a thin washer and shanked bolt putting pressure on it... they could atleast make a shouldered washer to give it some kind of support... in the bottom pic you can see the area you will need to grind off to clear the rack
