question about boost on high compression 408
Plus if you are running a PD blower you shouldn't have to spin it as hard to make the same power(or whatever your goals are)as the other guys therefore reducing heat soak, which means power. That would ring true with a centri blower too whether it be a procharger/vortech or whatever. Spin it easier which makes it easier for the IC to cool the air charge thus resulting in a cooler air charge and more power right? Plus the equipment(the superchargers)last longer because you are not running them right at their limits.
why are you not wanting to use meth or E85?
or you can use race gas
injection is nice, well u know the rest
you'll make much more torq with the blower and with the right cam the car would work great with a bit of drugs
