Aftermarket fuel rail question
Will the jet pump (or whatever its called to transfer fuel) still work when holley fuels rails? Is a check valve needed to stop fuel drainback?
If your car is 97-98 then you'll need a new fpr at the rails. If its a 99 or newer just stick with stock filter/fpr unless your gona upgrade it all.
