What to do to brakes to fit 15's?
Anyone have any pics of what has to be done on the rear brakes/suspension to clear 15" wheels, I know the LG spindles are needed, pop in the dimple, then some grinding on the lower control arms and brakes. Pics would be great if anyone has some. Thanks in advance for any help.
https://www.corvetteforum.com/forums...15-wheels.html
Not hard just make sure you are removal material from the right place...when the car is in the air compared to where it sits on the floor...
As far as the calipers just take of the most u can
Thanks for the input guys, doesn't look to horrible to do and I have access to a small manual mill which will allow me to do it cleanly if I go this route.
Received 1,762 Likes
I just put 15's on my car. It's amazing how much you have to grind off the lower arms to clear the wheel, plus the caliper required a pretty hefty amount as well. Definitely didn't expect it to be as much as I thought it would be.
But, traction was so worth it lol. Your car is gonna look sick with that wheel/tire/color combo.
