Fuel system design considerations and injector selection
Old 02-17-2015, 04:22 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06 is offline
Old 02-17-2015, 06:18 PM
MotleyDrew
MotleyDrew's Avatar
I love you
MotleyDrew is offline
Old 02-17-2015, 09:53 PM
Atrain59
Atrain59's Avatar
Great write up!
Atrain59 is offline
Old 02-17-2015, 10:13 PM
chris308
chris308's Avatar
Sticky worthy post!!
Ok, so now i have to ask... is the OEM filter E85 compatible?
chris308 is offline
Old 02-18-2015, 08:47 AM
69ls6
69ls6's Avatar
Originally Posted by breecher_7
Great information Bret!!
You must be waiting on parts for your car...
The only thing in there that I question is the heating of the fuel while running multiple pumps. On paper it makes total sense but I have set up two early C5's over the last couple years (one being josh's that you tuned) and in both cars I ran dual in tank pumps with the RSI hangar in a constantly on configuration and have not seen any issues with hot fuel that I am aware of. Both cars had the feed and return lines ran through the tunnel as well, so there was no lack of heat generated from other sources aside from pump turbulence/cavitation.
Under what circumstances have you seen this issue? The reason I ask is that I am getting ready to replace the pumps as its been about 5 years and its kind of a preventative maintenance thing and I was going to go from the current twin 255's to a set of ethanol friendly 340's.
This is way I always run external pumps on hobb switches.I never return much fuel.My last setup I used 2 044 pumps that came in @ 5psi and 12psi and over 1k rwhp with no issues.
69ls6 is offline
Old 02-18-2015, 12:57 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Bret no parts for the car & no other cars to work on at the moment.
Just kidding with you Bret very nice write up buddy...
robert miller is offline
Old 02-18-2015, 09:44 PM
lsxvette
lsxvette's Avatar
Default ,,,,,,,,,,,,
whats your take on return line size on a street car some say same size return as feed to stay cool ?
lsxvette is offline
Old 02-18-2015, 11:29 PM
Bryan@MCS
Navigator
Bryan@MCS's Avatar
Bret,
Great write-up!
Have you found anything that prevents the fuel from siphoning back into the passenger tank when the engine (and fuel pump) is shut off?
It looks to me that if the fuel transfer entered the drivers tank up high (in the airspace), then it couldn't siphon back to the right-side tank.
For allowing air inflow into the tanks during high fuel usage, do you think a -6 or -8 line with a check valve to prevent any outflow?
Bryan@MCS is offline
Old 02-23-2015, 04:33 PM
02402ramair
02402ramair's Avatar
Showoff
02402ramair is offline
Old 02-25-2015, 08:51 PM
Bryan@MCS
Navigator
Bryan@MCS's Avatar
[QUOTE=5 Liter Eater;1589047099]I have a bit of a worry about my transfer. I have the block off in the passenger side, no worries there. But my line from the main pump to the siphon pump is restricted, which makes sense, you don't want to be sending a ton of fuel over there. But I haven't seen any data to say how much flow/volume is required for the siphon to work, just pressure. I'll be running ~50# at idle. Still buttoning it up so haven't tested it yet.
I don't have any info on the later type transfer jet pump, but I disassembled an earlier (98 or 99) jet pump and the orifice in the pressure nozzle measured only .017"
I don't see a need for any upstream restrictor to the early-style jet pump.
Has anyone here pin-gauged the orifice in the later jet pumps?
Old 02-26-2015, 12:07 AM
KS Rebuilder
Support Corvetteforum!
KS Rebuilder's Avatar
I put 04 tanks in my 02 Z06, cross-referenced the wiring diagrams, dropped in a Aeromotive A1000, ran fuel lines in rocker, added a fuel pump controller(I made this sound easy-it is not, especially on jack stands). Had some fuel heating problems but it was due to not enough fuel pressure to siphon the fuel from the passenger tank. Turned up fuel pressure to about 56 lbs and it works great. I don't let it go below a half of tank on the gauge, this keeps the driver side full. Still not sure I will drive it when it is above 100 degrees out.
KS Rebuilder is offline
Old 03-02-2015, 09:14 AM
lsxvette
lsxvette's Avatar
with the way the factory tanks are done im shocked their are not many people useing/selling fuel cells for the trunks ..im in the middle of doing it now with a magna fuel system
lsxvette is offline
Old 03-02-2015, 12:52 PM
lsxvette
lsxvette's Avatar
Default re........
yea i guess in a hatch ...in a coupe you could block it off
lsxvette is offline
Old 03-02-2015, 08:57 PM
Racetronix
Supporting Vendor
Racetronix's Avatar
RXP255, RXP251, RXP252, RXP269
RXP340M, RXP341, RXP342, RXP369
DUAL PUMP ASSEMBLIES
DPA-510 @ 510LPH:
DPA-680 @ 680LPH
Racetronix is offline
Old 03-02-2015, 10:45 PM
Racetronix
Supporting Vendor
Racetronix's Avatar
Originally Posted by BLOWNBLUEZ06
This is exactly what I'm talking about. When I read the specs on this pump assembly, it reads "For customers who need enough fuel to support upwards of 1400HP". That's pretty useless information for someone building a car making 1400hp. Is that carbureted? EFI? At what pressure? At what voltage? I don't understand why anyone wanting to move product wouldn't publish all the usable specs and if they don't have them and can't come up with them on their own, I would lean on the manufacturer. How does that fit in a C5? How much current do they draw?
The specs on the 340LPH pumps are published above.
All of the pumps listed in this thread are generic and do not support the factory C5/C6 fuel system's jet-pump scavenging system and therefore are considered DIY items which require alteration of the factory module. DIY customers tend to formulate their own way of doing things based on threads such as this and we have learned respect their willingness to experiment and learn as they go.
We will update our wiring matrix chart for single and dual-pump applications to include C5/C6 platforms. This will make it simple for customers to select the wiring components they require:
http://racetronix.com/press-release/...ing-harnesses/
Here are a few notable C5/C6 items we have recently introduced to help simplify installation, improve pump performance and reliability:
http://www.racetronix.biz/itemdesc.a...PH-008&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...WH-033&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...WH-034&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...WH-008&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...U475-1&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...U476-1&eq=&Tp=
For customers who wish to retain the jet-pump functionality of their C5/C6 fuel system we will be introducing new PnP C5/C6 fuel systems incorporating our RXP 340LPH fuel pumps late this spring.
Thank you for your consideration.
Old 03-11-2015, 06:37 PM
Racetronix
Supporting Vendor
Racetronix's Avatar
Default DIY C56 Dual Pump Kit
This is our new DIY DPK for skilled installers. One complete solution with only the best components.
PLEASE CLICK ON THE LINKS TO VIEW DETAILS IN OUR WEB STORE.
http://www.racetronix.biz/customkiti...DIYDPK-C56&eq=
  • For HP upgrades from 600-1400HP
  • Twin Racetronix 255LPH or 340LPH turbine fuel pumps with reduced noise and enhanced reliability with E-85 enhanced fuels*
  • Stainless pump bracket
  • Billet dual pump coupler with Viton o-rings
  • Teflon 10 gauge PnP dual in-tank harness - E85 Compatible
  • High-pressure non-kinking fuel tube
  • Intermediate PnP Harness - 10 gauge wire
  • Dual PnP power harness - 10 gauge wire
The DIYDPK-C56 is recommended for factory HP upgrades from 650-1000/1400HP (gas). HP support will vary based on many factors such as fuel pressure, pump voltage, fuel line type/size, motor BSFC etc. Racetronix recommends a 20% safety margin for fuel delivery.
This kit is designed to fit in all C5 Corvettes manufactured 2003 1/2 and later with VIN # 114931 (last six digits) and up as well as all C6 Corvettes through 2013 excluding the ZR1.
Old 03-11-2015, 07:14 PM
Racetronix
Supporting Vendor
Racetronix's Avatar
Originally Posted by MVP'S ZO6
What about the 2003 and earlier C5's?
We have parts for that as well but the fabrication required to install the the DPA is considerably more involved.
To Fuel system design considerations and injector selection
Old 03-13-2015, 12:03 AM
stryderss
stryderss's Avatar
And those parts would be???? For the interested parties ofcourse.
stryderss is offline
Old 03-13-2015, 01:47 AM
Racetronix
Supporting Vendor
Racetronix's Avatar
We will put together a kit within the next couple weeks and post some information.
Old 03-13-2015, 02:47 PM
jimbos'ss
jimbos'ss's Avatar
I wish that jet pump was out before I cut up my stock bucket. Any plans to make a 400lph version? Also does it support E85?
jimbos'ss is offline
Quick Reply: Fuel system design considerations and injector selection
