Ecs oil adapter block mishap
I ran the C6 adapter block for a while before switching to the IR block so I can use braided lines to clear the headers. I noticed that it's easy to get the gasket out of alignment on the C6 block as you are installing it. I had a drip leak when I first installed it due to the gasket not seating correctly. Once that was positioned properly, no more leak. The IR block uses O-rings so the install is different in that you need to make sure the O-rings don't fall out as you seat it to the engine. Does the ECS block use either of these sealing methods?
at AN connections, no Teflon. Leave your header on, Clean it all off, make sure you have enough oil to run one more short test and start the car for 1/2 second. See if you can discover the actual origin. It might be obvious when you get down there anyway. With the Lingenfelter block, I had to clearance the oil block some to keep it from being pushed out/away by the LSX block, but it fit fine with the standard iron block.
If AN fittings are truly tight, it's either a defective block or leaking between the block and oil pan. hopefully you didn't strip the bolts that hold it on.
I bet its defective or improperly installed AN fittings. I used some Jegs brand ones last year for the exact same application and they leaked. At the time I swore it was the block itself and actually replaced it and it still leaked. Low and behold, it was just cheap fittings... Replaced with Aeroquip fittings and no problems since.
I appreciate the feedback guys even the Mexican 😄!ha !i don't remember over tightening bolts Bret .if it is a defective block , it may have q hairline crack in the weld that's not visible to the eye , I've seen it before only way to tell is to PT it or X-ray the block , pt is basically dye penatrant that u spray on like paint & everything turns white , if theirs a crack it will bleed red & gives away where the crack is located
Received 1,194 Likes
St. Jude Donor '15
I'd re-try with decent fittings. Fragola or Aeroquip seem to have far fewer issues.
