ls1 intake gaskets on ls2 manifold
Well im installing my ls2 intake on today took notice no notch for gasket to set in...
no biggie run to napa get gaskets for c6 vette..... no luck on gaskets they are special order gaskets..
s
can i jus trim the nipple off?..seem to fit well other than nipple on one corner to hold gasket in ls1 intake
s
ISIS SUCKS FAT CHOAD
Cut the nipple off with a razor blade. Looks like it will work.
You will know if it don't because you will probably develop a vacuum leak.
after some more research ls1 ls2 ls6 ls7 are basicly same gasket...
ls3 square port odd ball
needed a quick answer today was my day to put the intake on
mike getting tight in here lol
