Need advise on fuel system
I have gotten mixed answers to this question, I need some solid answers and I think you guys can help. Im setting up a A&A v2si kit on a 03 z06 with a 3.4 pulley 10-12 psi I believe. I need to know if a LPE pump swap and a boost a pump with 60lb injectors will be enough fuel to feed it. Also I will be running meth, however I would rather not be meth dependent.
Nope. Especially not with meth. Staying with 650rwhp or less 60's will be fine. I made over 600 on my last set up with 60lbs and no meth.
LPE pump
Racetronix harness
KB boost a pump
60lb injectors
606/531 with plenty of fuel
LPE pump
Racetronix harness
KB boost a pump
60lb injectors
Received 1,261 Likes
running 670 and 579 on 60s walbro 255, and racetronics harness with the KB BAP. no issues. I am running a single 15 nozzle Alky control kit. hope this helps
Received 1,195 Likes
St. Jude Donor '15
