A&A vs ECS blower kits
I'm going to be ordering either an A&A or an ECS kit soon and I will be using a Novi 1500 head on whichever. I am new to supercharging and have not been able to "eye ball" these kits in person. And, before you flame me, - yes, I've searched the net, read and gone to the vendors sites for info.
My problem is I don't understand the basic differences in these two kits, especially the way they mount the radiator and the intercooler. Do both either lower or lay down the radiator? Are the intercoolers basically the same? Is there a major difference between the two or is it a toss up. Please chime in with your kit preferences and reasons. This will help me decide on a direction.
I can't help you with all your questions, I have the Novi2000 from 07'. What I will say, since you already know you want a ECS blower, why would you not buy a ECS package? I realize the importance of opinions from the forum, but have you spoken to the kit designers yet? I don't see any real reason not to use the entire package designed by the guys who build them, race them, and use them daily.
A&A vs ECS
So rather than jump into the ECS I've asked knowledgeable guys who have experience with these kits and that CAN answer my question to help me decide if either is superior to the other.
Both kits will effortlessly make 900+whp with a YSI/2200R in their 8 rib configurations.
Both kits are well engineered and perform very well. Their are small pros and cons to both kits.
As you are interested in running a novi 1500, either kit will work just fine for your power goals. The ECS kit does offer easier belt changes, but if a belt id aligned properly it will last years anyways. Ive seen both tensioners break in high horsepower applications.
(900+whp, 10 rib drive)
To me, it would boil down to what you can get the best deal on as you cant go wrong with either kit.
Received 1,261 Likes
the ecs kit uses an aftermarket cradle that not only lowers the radiator/condenser/intercooler but it also tilts everything back towards the motor while the a&a kit uses spacers to lower the factory cradle straight down... you can also just use your factory cradle and have the mounting tabs cut off and rewelded in a lower position that way you aren't losing any ground clearance but have room for your inlet to clear... ecs now supplies all of their kits with a much smaller intercooler, it is the same one found in all of their c6 kits... to my knowledge the original intercooler is now an upgrade but it doesn't seem like many people are aware of that when they buy their kit... the a&a intercooler is boxed in which forces the air through it while the ecs has no framing around it so air is free to move around it instead of through it... both have a 3" inlet and I believe a&a has a 3" outlet while ecs uses a 4" outlet
Here we go again. Some like the ECS, Some like the A&A. Both are great kits.
I have an A&A kit on my Z and am very happy with it. I have installed both kits.
I appreciate you taking the time to post but how does your post help me?? I am aware of the quality of the kits. But if you will reread my initial post I am asking for information from experienced users about generalities as well as some specific areas. Not trying to be an a$$ but if you have to start a post with "here we go again" and then contribute nothing then I really don't understand why you are here unless you just had an extreme urge to type.
I think what was meant above is that there are many threads on this same topic if you care to look. The subject has been beaten to death with always the same results. Both kits are good.
Resist the urge to type and search and read instead.
Good luck with your decision.
You just called one of the most politefull, experienced wrenches and drivers on here an a$$. The reason you won't get a response is because this thread has been beat to death on both the corvette C5 and C6 FI sections. Use the search function and Google. I've had 2 of both kits on my cars.
I hesitate to even reply to this but - can you read? I ask again to please reread my initial post. If don't know if you're just trying to cause confusion or what. This will be my last reply to you. Good luck to you also.
triblk6spd (09-13-2016)
ISIS SUCKS FAT CHOAD
The real down and dirty is that both kits are light years ahead of the kit that procharger sells for the c5.
A&A pros the only legitimately carb legal kit available (I don't care what anyone else try's to tell you the others technically are not carb legal).
A&A is cheaper for the amount of intercooler you get (more on that in a min)
ECS Pros
Can be ordered with a larger intercooler (but cost more than A&A)
Blower belt changes are much easier.
Tensioner is more robust.
Now on to the intercooler thing.
A&A has one standard intercooler as its been stated they stand straight up and are in the front end air flow stream more than the larger ECS or smaller ECS intercooler.
Before ECS had the small intercooler as standard on their base kits; they were more expensive than the A&A kit.
Now with the smaller intercooler, they are the same price (maybe a little cheaper) than the advertised price of base A&A Kit. However, that standard intercooler ECS offers is awful small, though ECS ensures it is plenty for their base kit. Based on what I've seen of the new base ECS intercooler it is about the same width and height as their big intercooler but half the length.
If you are looking to make 1000 WHP @ 20 psi or more reliably, than neither kit in its base form will work without additional upgrades or modification.
Everytime I've called ECS, they have got back to me in a reasonable time except for the weekends (which is understandable I guess)
Everytime I've called A&A they have got back to me with in a reasonable amount of time including the weekends) I'm pretty sure Andy forwards all the shop calls to his personal phone on the weekends.
For me, Andy has personally came out to his shop on the weekend to get parts for me (but I'm somewhat local)
Would ECS do it? I don't know maybe.
The rest I will pm you. It's not that it's bad it's just stuff I can not discuss in public.
ECS Pros
ECS Pros
ECS Pros
ECS is a more thought out kit for making bigger power. A&A is priced better and will appeal to the masses more.
Both have good customer service. ECS website sucks ***** though, they would probably get more sales if they mirrored A&A's website.
Agreed on the website layout!! Andy makes it easy.
Agreed on the power making too!!
Though cars like yours and mine overcome either base kit.
ECS kit blew my motor!!!
