Those who have Kenne Bell blower step inside
I'm doing some research and i'm not seeing too many people running these blowers. I'm sure there are at least a few on here that have them installed. I'm not looking for a peak HP number but I want a fun street car and want to be different. Can you post up pics of your setup and talk about the pros and cons of this particular blower setup?
Received 1,762 Likes
Look at a turbo are a front mount blower you will be much better off. Now for your second CON to me, why do you want a blower on your car that totally come in full power under 2700 RPM all you are going to do is spin your tires off & up in smoke. If your not moving you will not win a race.
But the KB is fun if that is what you are looking at doing in your car.
I had one IAT out of the roof, heat build up had to go with aftermarket radiator. Kenne Bell was so bad on the vetts kenne bell stopped making them for the c5 vette.
If you want to go PD , get the new heartbeat, or jackshaft Maggie TVS 2300, or the edelbrock. You can make these fast, but it takes more cash,
If you want to go extreme, go with centri.
Huron speed is coming out with a new twin turbo kit soon, if I was starting, I would wait for that.
Robert is right, very few kenne bells here.
I run the jackshaft Maggie, it makes a fun street car!!
Hi , few years back now but might be of interest .
https://www.corvetteforum.com/forums...g-fun-yet.html
For what I wanted out of a blower it was great 533 rw out of the box , stock motor .
I personally never had any problems at all .
I sold the car a few years back , and wished I hadn't , so got another z and have gone TVS2300 .
If you do go with that KB , try and make sure you get ALL the parts from the seller .
Centri`s are the most popular ,I have zero knowledge of them , think I just like the look of a PD blower on top of a motor .
See if you can get a ride in a TVS car and a centri
I have a KB blower. I like it but if I could of done it over I'd of went with something else. I'm just under 600rwhp and I've had it for at least 5 yrs now,probably 40,000 miles. I like the looks of the polished KB over the front mounted ones,but I think those are better,lot less heat under the hood. My cars not the fastest Vette,but it does get out of its way when needed.
I have been running a KB since the beginning of the kits. Has always turned more heads than any other car at the meets. The power comes on from 2000 rpms and feels like it never stops. The only downside I have ever had is the high IAT's but that can be tamed a little with a bigger coolant reservoir. A lot of the mustang owners are running 2-3 gallon tanks and it helps. I know im not going to be the fastest on the street but that does not matter to me. Its about the experience and being different than the hair dryer guys.
St. Jude Donor '17-'18-'19
That blower would turn ice into scolding hot water in the matter of one dyno pull.
