**Finally getting blown**
Old 04-11-2015, 01:08 PM
JJ 86
JJ 86's Avatar
Default **Finally getting blown**
I'll be ordering a Blacked out V3 Si A&A kit soon. After years of wanting a supercharger I'm finally ready to take the plunge. My car is a 03 Z06 basically stock with the exception of Corsa extreme exhaust. Car only has 21k miles. Is there anything that I should look into getting once the supercharger is installed? Should i upgrade the valve springs as well? What size pulley does everyone recommend? Would love to make close to 600 rwhp but would be happy with 550ish.
Old 04-11-2015, 03:05 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
3.4 pulley. PM sent.
Old 04-11-2015, 05:31 PM
fisher auto
fisher auto's Avatar
Old 04-11-2015, 08:44 PM
meine96ws6
meine96ws6's Avatar
Definitely look into hardened pushrods, dual valve springs, and a trunion upgrade kit.
Cheap insurance for you sping tje motor high.
Old 04-11-2015, 10:02 PM
TheCartel
TheCartel's Avatar
Glad you didn't do that kb! You'll be happier with this choice!
Old 04-11-2015, 10:29 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Nothing like getting your first blown car. You are going to love it.
Old 04-12-2015, 09:15 AM
dcase4246
dcase4246's Avatar
Congratulations!! I am also getting a A&A kit at the end of the month. I cant wait.
Are you installing it yourself or is Wes going to do it for you? Good luck with everything.
Donnie
Old 04-12-2015, 11:08 AM
JJ 86
JJ 86's Avatar
Donnie
Thanks! I will be installing the kit myself and Wes will be doing the tune once I'm finished.
Old 04-13-2015, 09:30 AM
95rtturbo
95rtturbo's Avatar
Clutch definitely, and tires. I doubt you will see anywhere near 600 to the wheels on a stock C5 Z, with an S trim. Probably low 500s. It will still obviously be a ridiculous difference.
I am running a T Trim @ 12 PSI peak, on pure 93 octane, which put down 640 WHP SAE, and it is a blast (went from long tubes, intake, and tune to this). I went with a Mcleod RST twin disk, mated to their aluminum flywheel, and the Tick Master cylinder (also replaced the slave cylinder with a new GM slave cylinder). For tires, I went with Toyo R888s (305 rears, 275 fronts) - they hook pretty well at this power level.
Old 04-13-2015, 09:04 PM
Blitzkrieg
AKA "The CLOWN"
Blitzkrieg's Avatar
Glad your getting Blown, sure wish I was…………………….
Old 04-14-2015, 11:09 PM
2003Evo
2003Evo's Avatar
The only way you going to get to 600whp is by adding long tubes and offroad xpipe...other than that good luck and enjoy the new power. SC is def the way to go
Old 04-16-2015, 12:40 AM
Forcedvert
Forcedvert's Avatar
I'm far from an expert (unless you count breaking stuff) but if prop shaft couplers are original rubber the low miles are only half the formula on longevity, I think rubber will get weaker over time no matter what the miles, I saw mine today, only 3000 mi and 1 year old and they were twisted and warped and would have been a problem soon if trans didn't go first. So spinning the tires is probably better than hooking up solid until you are ready to spend a lot more money. Horsepower is addictive but torque is the devil!
Good luck
Adam
Old 04-16-2015, 01:33 AM
jbsblownc5
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Congrats, and enjoy the ride!!
To **Finally getting blown**
Quick Reply: **Finally getting blown**
