Are upgraded valve springs needed? 10-13 psi
Trying to determine if I would need to replace the stock valve springs on my 2003 z06 with 23k miles when running 10-13 psi of boost... thanks
[QUOTE=jmd1487;1589414766]yes its an early 2003, what springs should I purchase?
Stock springs will work, as defects were corrected in future revisions. I wasn't sure if early 03 was 100% in the group of spring issues, I 100% know 02 was though.
http://www.summitracing.com/parts/nal-12499224
[QUOTE=nullpointer;1589414875]
perfect thanks!
I had valve float with stock springs on mine. I had planned to run the stock running 8-9 psi. Numbers were low. Discussed with tuner and on this forum that maybe the springs were the problem. I replaced with PAC single springs. Gained 60-70 hp by swapping them out.
jfyi type of stuff.
Link to my thread...
https://www.corvetteforum.com/forums...-ecs-novi.html
jfyi type of stuff.
jfyi type of stuff.
jfyi type of stuff.
Here's what I have in mine and it is cheap insurance and pretty easy to change with a spring compressor, air compressor and pin magnets.
.625" Lift PAC 1211X Beehive Springs
PAC 1211X 1 $169.00 USD $169.00 USD
LS Chromoly Pushrods 7.400" long
PR7400312 1 $89.00 USD $89.00 USD
Stock springs are pretty weak. Their effective pressure is further weakened by adding boost. No way I would keep stock springs on it. A valve train that's out of control can damage your motor a lot more than most folks seem to think. It's too cheap to not do.
