WTB: Procharger twin intercooler rubber piping
I am looking for some rubber piping pieces that go with a twin intercooler procharger system. I scraped one of mine, and just seeing if anybody had some lying around. I may check with this rubber gasket and piping place near me and see if they have anything. The rubber connector I need is the 45 degree one that connects to the 90 degree one coming off the intercooler to the charge pipe.
I have worked and worked with these pipes and this is the highest I have been able to get them to tuck. I'm hoping I can play around with some of the piping and see if I can get it to go on up a little more when I install a modified ecs radiator cradle. Might allow me a little more wiggle room. I appreciate the input.
Yeah, I'm running stock cradle. I called procharger and they want $409 for their cradle. I'm thinking of getting one from ecs. It should work with my setup.
Received 1,261 Likes
when I got my kit from ecs the rubber 90 degree hoses had napa stickers on them... I don't remember the part numbers but you might try them out, surely that stuff couldn't cost too much
I checked, but I have the ones that are close to a 90. 45 would be a tighter bend, I think you mean sometime like a 135 deg. I had to reconfigure my whole system when I added a Dewitt's and Spal fans, I found what I needed on eBay, used silicone houses.
