Feedback on JEGS SFI Supercharger Balancers
Received 1,193 Likes
St. Jude Donor '15
I'm using the Summit one. Is it the same? It has worked fine for me for over 10K miles. I'm running the 6 rib base ECS kit and original pulley.
C2501
http://www.summitracing.com/parts/sum-c2501
C2501
St. Jude Donor '15
Yeah the Summit one is stock size and fairly cheap
Got a link to the Jegs one?
This one? http://www.jegs.com/i/JEGS-Performan...ductId=1679269 ?
The only thing you need to watch for is the bracket spacing. Are you currently running 8 rib with the 8 rib spacers etc? If not you will likely need to. The bracket will hit it if not.
Pm A&A about using an 8 rib OD balancer with their kit.
I am also using a 6 rib blower set on the 8 rib balancer but I have the procharger bracket. Like I said the only issue you may run into is if you are running a 6 rib A&A bracket set up because the bracket will likely contact the 8 rib balancer since it is wider.
You can fix this by using the 8 rib spacers etc to space the bracket out from hitting the balancer. A&A can help you make it work correctly if needed.
Do a search. I made a thread about this pulley a year or two ago. "Jegs" in your search should pull it right up. It has worked fine for me fyi. Im running the 8 rib OD with my blower at ~650whp with no problems.
