New Comp Turbo CT2X5858 .63A/R oil-less twins
Old 05-12-2015, 07:50 PM
2sikDET
Cruising
2sikDET's Avatar
Default New Comp Turbo CT2X5858 .63A/R oil-less twins
Thought I would share some pictures of the new set of turbos I purchased from Huron Speed Products here in Michigan. The turbos were build at Comp Turbo out in California. I own a 2001 Z06 with an STS rear mount kit. The new turbos have the oil-less triple ceramic ball bearing center cartridge. Water ports are build in for cooling and an update to this design is the ZERK fitting for easy greasing. The cartridges use a proprietary grease from Comp Turbo. Soon to be installed. Should be a great update over the base Garretts. Rated at 600 horse power. COMP TURBO CT2X5858 .63A/R with the T3 4 bolt turbine housing. Easy drop in upgrade to the STS kit. Enjoy the pictures!
Old 05-12-2015, 08:27 PM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Nice looking turbos. Now hurry up and swap them in
Old 05-13-2015, 07:14 AM
Hammer
Support Corvetteforum!
Hammer's Avatar
Nice
subscribed
Old 05-16-2015, 09:24 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
In for the updates!
Thanks,Matt
Old 05-22-2015, 09:21 PM
albrntout
albrntout's Avatar
Wow how did they work out? I'm just getting an old kit revived on my car. Turbos are starting to look tired, super curious!
Old 05-23-2015, 08:55 AM
2sikDET
Cruising
2sikDET's Avatar
The install is scheduled for this coming week after the holiday weekend. I'll post the finished pictures soon after. Should make an excellent upgrade.
Old 05-26-2015, 11:34 PM
BABYBUGY
BABYBUGY's Avatar
looks good interested in longevity
Old 05-27-2015, 03:17 PM
Smoove
Smoove's Avatar
What size turbos are you swapping them with? A/R?
Old 05-30-2015, 06:58 PM
2sikDET
Cruising
2sikDET's Avatar
I'm not sure what the original STS Turbos are in sizing.
Old 05-31-2015, 10:27 AM
venomws7
venomws7's Avatar
Very nice love those Comp setup.
Keep us posted and please get some install pics.
Old 05-31-2015, 11:34 AM
c5wolf
c5wolf's Avatar
I just swapped my stock sts turbos for the 5858 precision
Ball bearings with a .63 a/r and omg what a difference!
Doesn't whistle as much but it hits quick and as hard as your controller
Tells it too
Old 05-31-2015, 11:38 AM
venomws7
venomws7's Avatar
How are you planning to run the water coolant to the turbos?
Old 05-31-2015, 08:25 PM
2sikDET
Cruising
2sikDET's Avatar
The shop I'm working with is fabricating some hoses to run from a connection out of the coolant hoses up front and then all the way back, basically in the same positions that the STS oil lines ran underneath the car. I'll post some new pictures soon.
Old 05-31-2015, 08:53 PM
2sikDET
Cruising
2sikDET's Avatar
Tells it too
Right on man! How has your kit held up since you have been running the STS set up?
Old 06-01-2015, 03:37 PM
venomws7
venomws7's Avatar
Yes please get some pics I'm really interested in something similar best of luck
To New Comp Turbo CT2X5858 .63A/R oil-less twins
Quick Reply: New Comp Turbo CT2X5858 .63A/R oil-less twins
