Injectors(around 80lbs) that do not use plug adaptors ???
Quick and easy one for you all.
My deatshwerk 78lbs are in .Since they dont use the stock corvette injectors connector, they are sold with some adaptors.
This is my personnal taste but i dont like adaptors.I would like to have a injectors set that connect directly to my stock c5 injector harness without any adaptors???
What model am i looking for ???
Eric
Eric
ISIS SUCKS FAT CHOAD
You could to just repin the harness with a different terminals and housings for whatever injector you want.
Most big aftermarket injectors use an EV6 connection on their injector. Your car uses an EV1 connector hence the need for the EV1 to EV6 adapter.
The ford injectors use the EV1 connector I believe.
Supporting Vendor
I can get you a set of 80lb Siemens Deka that have the proper connections or if you want some growing room and to keep your duty cycle down (has an added benefit), you can try the 127lb.
PM me for pricing and let me know your shipping info so I can give you a total with shipping.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
http://www.racetronix.biz/itemdesc.a...114992&eq=&Tp=
Im sure that Bownbluez06 would take care of me but im from Quebec,Canada and Racetronix is in Ontario so shipping is quick and inexpensive.
Also if those are the good one, does anyone got a gm calibration data spread sheet for those injectors ???
Eric
EDIT: I ve sent you a pm
I don't know much about the racetronix stuff. I've had questions for them in the past concerning purchased products and they are often difficult to get ahold of. Not having a published phone number isn't any help either.
On that note I've bought a lot of stuff from blownbluezo6@rkt56 He's always easy to get ahold of for technical questions. I guess I kind of see it as a service he provides to anyone who buys product from him.
Thanks,Matt
Well thanks everyone.
Since my deatshwerks are new im gonna take MVP'S ZO6 idea/solution and change my ev1 plug to a ev6 plug.Ive bought 8 of these: http://www.racetronix.biz/Itemdesc.asp?ic=ICAU8&eq=&Tp=
Come with 8 inch of wire and even heatshrink included,Only required some little soldering.Total cost 32$
