A&A V3 SI install question
Old 05-14-2015, 12:33 AM
JJ 86
JJ 86's Avatar
Default A&A V3 SI install question
I'm finishing up the install of my A&A kit. Would it be okay to drive the car to the tuner which is about 30 miles away (60lb injectors installed)? Or should i find someone with a trailer to tow the car to the tuner?
Old 05-14-2015, 01:21 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
leave the stock injectors in, drive it to the tuner, and swap them out there... just stay out of boost and you will be fine
Old 05-14-2015, 03:34 AM
Moonder
Moonder's Avatar
+1
Old 05-14-2015, 06:19 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
MVP'S ZO6's Avatar
If the car will start idle and run with the 60's put them in and drive civilized (no boost no big throttle transitions) and you will be fine.
If it don't. Keep the current injectors in there and same thing drive civilized (no boost and no big throttle transitions) and you will be fine.
Old 05-15-2015, 01:04 AM
JJ 86
JJ 86's Avatar
Thanks for the info everyone! Install is now complete. Now just waiting on the tune..
Old 05-15-2015, 01:58 AM
MVP'S ZO6
MVP'S ZO6's Avatar
Cool!! did she fire up and run with those larger injectors?
Old 05-25-2015, 11:54 AM
JJ 86
JJ 86's Avatar
For the time being I just left the stock injectors in the car so I can drive to the tuner's then will swap out to the 60 lbs injectors.
To A&A V3 SI install question
Quick Reply: A&A V3 SI install question
